OEM Fog light issue...electrical people step in
Old Nov 30, 2004 | 07:45 AM
nupe500's Avatar
Jedi Knight
I've been running these aftermarket foglights and decided that it was time to put the OEMs in. I got a set from my cousin's 97 maxima, and they were not working, I figured the bulbs were blown. I purchased new 55w H3 bulbs and installed them. I go to test the foglight yesterday and to my surprise NOT one of the foglight went on...confused, I double checked my aftermarkets and they still worked, keep in mind that they were wired to the stock harness. I am wondering if anyone else has had any kind of issue. I'll be doing some more tinkering..later checking for continuity and such, but I'm a bit baffled...
Old Nov 30, 2004 | 09:06 AM
[s3]'s Avatar
Maybe you spliced the wires to the aftermarkets and chewed up the stock plugs...
Use a multimeter and check for power, or simply poke it with one of those lite up voltage picks.
Old Nov 30, 2004 | 09:48 AM
nupe500's Avatar
Jedi Knight
that would be a thought, but I merely used wire taps...for the aftermarkets...knowing I'd likely come back to stockers
Old Nov 30, 2004 | 09:50 AM
[s3]'s Avatar
What *might* have happened...is that the wire taps cut the original wires and you're only getting power to the tapped side.
Again, use a multimeter and check both places.
Old Nov 30, 2004 | 12:12 PM
ny96max's Avatar
definitly check and see if those wire taps cut power flo to the stock fog harness plug. I would take those off and return the line to factory.
Also check and make sure your h3 bulb is clipped into the internal hanress(inside the fog housing).
Ant
Old Nov 30, 2004 | 01:23 PM
Nismotic's Avatar
Always sunny in philly
Ola, if it turns out to be the harnesses, i got a pair for ya. let me know
Old Nov 30, 2004 | 09:07 PM
nupe500's Avatar
Jedi Knight
Q,
I may take you up on that offer. I think you fellers would be greatly interested in what I found out.
here it goes: As I had the wiring setup, by splicing into the factory harness, but keeping the factory connector on it. Being a bone head when I installed the fogs, I didn't seal the factory plugs so essentially what happened was that there was power on the positive wire of the exposed plug, which combined with rain/weather corroded. It makes all the sense in the world...but atleast I've figured it out.
Q- I'll hit you up sometime this week. Thanks bro!
Thanks to all for the input...
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
