thermostat issue
thermostat issue
Thermostat Issue,
Some months ago the thermostat didn’t open and it blew my radiator. I removed the thermostat and replaced the radiator. Lately, it is getting to long to warm up in the cold mornings, so I bought a thermostat and have it installed. When I tested it the first time, I assume it didn’t open because the temp went slightly above the middle and the fan had to use the faster mode, (the temp never goes above the middle). So I turned off the car before it was too hot. I have a VG, is there any special procedure to install the thermostat, besides what comes on the Chilton’s.???
My car never uses the fan’s second speed.
Originally Posted by VG Ill ridah
Did you check you coolant level first? What water coolant mixture are you using and is you heater core good? Why replace the t-stat and radiator again if just replaced them?
He has a VG, so that means the heater core has air in it. I remmember an old post were the front of the car has to be raised really high so that the air can leave the heater core. then finish bleeding the system.
Also whenever buying a thermostate to get a 'failsafe' one. The original should have been a failsafe. This is a part that no one should cheap-out on.
Also your radiator may have a bad 'cap' that did not open when your car overheated, so replacing the cap is apart of a cooling system tune-up.
Originally Posted by alpicone
Did you open the bleeder valve when you refilled the system? If there is air in there the car will overheat.
You are right, I opened the valve and the air went out. Everything is normal again. I did not have to raise the vehicle, just opened the valve and that was it.
Thanks to all of you guys.
Originally Posted by DanNY
VG motors: 10mm bolt on top of the intake manifold. in front of the PCV valve
thanks for the pic, went to a huge hill 70% incline and (while running not recomended i know proceded to bleed off the car. Heat worked wonderfully on the hill. how long does it take to bleed off the system as to eliminate the over heating issue. as soon as i left the hill heat went back to being cold and car proceded to overheat again but a ton of air was removed. any idea other than parking on the hill and letting father time weep the air out of the system to get it blead off. really need to solve this issue. any imput (other than questioning my logic on bleeding it off while running would be greatly appreciated. thanks
Air comes out while driving with a leak. Produce a tiny leak [loosen a clamp?, bleeder valve] on the highest coolant point and drive one hour, while keeping coolant level adequate. Typically necessary; in two vehicles I had it was the only possibility.
Originally Posted by Foufyter
thanks jacked her up and ran for an hour with the bleed valve cracked open and now heat works fine and - overheating
Its good if that worked while stationary. In those my serious ones, I had to have revs above 2000 (so I drove around). I now think that this longer bleeding takes all the real small bubbles from the coolant out that tend to form gasbubble blocks.
House central water heatings have automatic bleeders, so why not cars. I quess it would save a lot of gaskets? But that would be bad for business...
Btw. My temp gauge needle also goes never up the half. Still its hot inside in -10F. Maxima is a warm car, which is atypical to japanese cars.
RWCreative
Sep 21, 2015 11:01 AM
97_GXE
20
Sep 17, 2015 08:12 PM
aminus21
Sep 12, 2015 04:53 PM
