123 only
Old Dec 9, 2004 | 12:55 PM
fred's Avatar
123 only
when i start my car in the mornings, i let it warm for about five minutes, then i leave. the problem is that it wont shift into 4 for 3-4 miles or the last little drop (overdrive?) untill about 15 min. after the engine is completely warmed up or i am 10-12 miles away. is this a problem that i need to worry about? am i harming my flimsy gxe tranny? btw if i let it warm longer before i leave it upshifts sooner
Old Dec 9, 2004 | 01:01 PM
Loe max's Avatar
Thats normal with most late model automatic transmission cars. It allows the transmission fluid to get up to normal operating temperature sooner. As for your last question, you shouldn't rev your engine too high until you physically see your temp gauge move slightly past the 'C' mark. Since most of my driving is city on my way to work and school, I never shift into 4th or 5th until I see the temp gauge move slightly above the 'C'
Also, IMHO 5 min warm-up is alittle too extreme, I've never warmed up any of my cars for more than 10 seconds, even on a cold morning no matter how cold the air is blowing out of the vents.
Old Dec 9, 2004 | 01:14 PM
internetautomar's Avatar
mod or sell?
I used to let my car warm up 15 minutes when I had the remote starter on it.
Old Dec 9, 2004 | 01:59 PM
fred's Avatar
ok thanks!
Old Dec 9, 2004 | 07:05 PM
Minty91GXE's Avatar
i've seen a consensus that you shouldn't push past 3000 rpm till the car heats up and that you shouldn't warm the car up by idling more than a minute or two, its better to drive slow to get there.
personally my gxe, as minty as it might be, runs like **** until the oil temperature rises, thats usually about 1/2 a mile of slow driving.
T
Old Dec 10, 2004 | 05:19 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
my remote start cuts out at 12 minutes
Old Dec 10, 2004 | 07:46 PM
whitemax28's Avatar
mine shuts off after 20 min
Old Dec 10, 2004 | 11:13 PM
acidspit86's Avatar
dont you want to use a higher gear to lower the revs?
Old Dec 11, 2004 | 08:44 AM
Loe max's Avatar
Speed limit around rush hour is 20-25mph where I travel So 3rd gear is at about 1,400-1,600rpms
Old Dec 11, 2004 | 12:28 PM
acidspit86's Avatar
ah i see123
Old Dec 12, 2004 | 06:53 AM
kblast523's Avatar
Speed vs cold
1990 Max with 118K, sat for about 3 weeks (out of town) started right up, drove about 150 miles over three days, parked. Sat another 6 weeks (out of town again) and when started, it was 45 degrees colder than when parked. Backed out of garage into the cold and IMEDIATELY started dead miss on two cylinders. Talk about slowing you down...
No history on tunes, but that is my project today...Cap and wires look factory, and who knows about the plugs, but its been getting much worse mileage. Miss went away about the same time temp guage left the peg, but after one heat cycle, returned. My guess is 70-80K mile old plugs...
Where I live, 5-30 synthetic helps "warm me up" a lot quicker. Looks like we are going to have a cold one this year...
Old Dec 15, 2004 | 02:37 PM
fred's Avatar
if i were you i would replace the plugs, wires and cap...they really do help alot...and yes using 5w30 helps when its cold, because the oil is thinner to begin with.
Old Dec 16, 2004 | 12:18 PM
bkea's Avatar
Honda owner's manuals state that their transmissions do that intentionally. It is programed in to help with emissions. The engine turns a little faster to warm the engine up faster to lower emissions. Or so I heard.
Emissions is also why mfgs say don't idle a car after cold start up. Burning gas and going no-where.
Old Dec 16, 2004 | 04:33 PM
longpole938's Avatar
you also dont want to idle for too long cuz you engine isnt designed for it.... no car is. they are meant to have a load put on them.
Old Dec 17, 2004 | 05:28 AM
mod or sell?
incorrect, the crown vic is designed to idle all day long.
Old Dec 17, 2004 | 06:43 AM
yelowd's Avatar
Fred,
I'm up in the tundra, too, and my 90 SE auto does that as well. I had the same panic attack at first, but i figured it just had to be cold since the tranny shifts fine all the other times. The other thing mine does if I don't plug the the car in at night is clatter like unholy banshees for about 30 seconds. And then it goes away mysteriously. I think one or more of my injectors may be bad / weak and fail in the cold. That's the only thing I can think of.
Old Dec 17, 2004 | 01:36 PM
fred's Avatar
yeah mine clatters too, but only for a few seconds. and i dont have a block heater, i should really get one, i have a feeling the rest of the winter is going to be cold when i need my car to start thanks
Old Dec 17, 2004 | 06:17 PM
Loe max's Avatar
10char
Old Dec 18, 2004 | 09:47 PM
eric93SE's Avatar
Yeah you guys should use synthetic if you aren't already, at least during winter time, as well as a filter with a good anti-drain back valve. My max also won't lock up the TC when in really cold temps. It rev's about 200rpm more than normal for a couple miles. I have a tranny cooler, so I usually block it off during winter months (also syn ATF).
DA-MAX
Nov 16, 2005 06:17 PM
xorbitman
Nov 16, 2004 12:37 PM
paul-e
Oct 2, 2001 04:07 PM
