burnt headlight harness!!!
Old Dec 11, 2004 | 11:37 AM
joe4's Avatar
i have some hyper white chinese bulbs that have burnt the harness before. i replaced them with some autozone harnesses. one burnt again last night so i replaced it again. on the bulb, it has 80/100 watts. is that the reason it keeps burning up. i found some apc superwhites for the car. ther bulb has 65/85. would those be safer for my car. i really dont even use high beam because i have really good fogs. please help.
Old Dec 11, 2004 | 11:49 AM
Wiking's Avatar
"burnt the harness before"
Make your own wiring. Take finger thick wire from battery to headlights, install relays for each lamp [quite a job to tame that wire]. Now voltage at lamps does not drop anymore, you have bright lights with std bulbs. And. Wires will not melt anymore...
Old Dec 11, 2004 | 12:29 PM
Cliff Clavin's Avatar
Way out West
I think in the stickies Craig has a "how to" on rewiring your headlight harness.
Old Dec 11, 2004 | 10:29 PM
joe4's Avatar
truthfully its not that serious for me. i just want to know if those bulbs will be safer by being 65/85 instead of 80/100. will the 65 do the same thing or will it be ok. im not looking for the super duper hid look. i just want to avoid those yellow looking lights by all means necessary. the only reason i had those bulbs is because they were out my other car.
Old Dec 11, 2004 | 11:17 PM
alpicone's Avatar
Those cheap eBay bulbs will do that to your wiring. Either upgrade your wiring or use some Silverstars.
Old Dec 12, 2004 | 12:42 AM
James92SE's Avatar
2 VE's are better than one!
I just recently got some Silverstars in my E36's and I must say I'm HIGHLY HIGHLY HIGHLY disappointed. Good thing I got them half-price on Ebay, but still... I couldnt be less impressed. They're just barely brighter/whiter than my stock yellow halogen's
Old Dec 12, 2004 | 04:21 AM
Hectic's Avatar
i'd say the heat is burning the wires...go buy some ge's
Old Dec 12, 2004 | 07:09 AM
internetautomar's Avatar
mod or sell?
the key to good light output is not wattage.
it's the gas used in the bulb and quality of said gas.
Old Dec 12, 2004 | 07:53 AM
joe4's Avatar
well the bulbs are at circuit city for 10.99. they are the APC Superwhites with xenon gas. so will those do since their not china man made. i had silverstars before and they were not worth no 20 bucks a bulb.
Old Dec 12, 2004 | 10:09 AM
Way out West
If you already burned your harnesses, you are going to have to replace the wires. You might as well do as I suggested in my first post and rewire them with better wire. That way, when you drop in more crap from APC, it won't burn the harnesses again.
If you are going to stay with stock wattage and go with a "whiter" bulb, I recommend XD5 bulbs. I have them in my car and they are significantly better than stock (both in light output and "whiteness" and I have had them for over a year and not burned one out yet. I also have XD5 bulbs for my fogs, but I took them out for winter and put in some Hella yellow gold bulbs.
Old Dec 12, 2004 | 07:09 PM
andy044's Avatar
RWD bolt-on conversion?
help me out
i just got silverstars for my bday
i put them in a week ago
last night the rright blew up literally
i wasnt strobing the high beams or anything, i didnt even drive over a bump at all
i just went to switch to highs went i noticed only my left was working. so at home i checked the fuses, which wer okay
i looked inside the hl enclosure, and sure enough i see little peices of silverstar glass inside.
What the **** happened??!!
they were 9004 ST
i wrote Sylvania and email aswell, but i dont thinkthe'lyy help because i dont have the reciept.
Old Dec 12, 2004 | 09:20 PM
joe4's Avatar
thats what happened to one of my silverstars. i dont know if it exploded or what. but when i noticed one of my lights were out, sure enough if was broke into little pieces.
Old Dec 13, 2004 | 06:25 AM
DanNY's Avatar
Ad·min·is·tra·tor
Originally Posted by andy044
help me out
they were 9004 ST
you touched the glass or the glass came in contact with something oily. the heat from the bulb cooked the oil on the glass and it blew up the glass.
cause - user/installation error (RTFM).
Old Dec 13, 2004 | 07:06 AM
Greeny's Avatar
¯\(°_o)/¯
I would guess and say fingers.
Old Dec 13, 2004 | 11:26 AM
andy044's Avatar
but i even cleaned the bulbs befor i put them in witha soft cloth
and i was extra careful
damnit
19.99 down the f'ing tube
Old Dec 13, 2004 | 11:29 AM
DanNY's Avatar
Ad·min·is·tra·tor
damnit
what did you use to clean the bulbs?
Old Dec 14, 2004 | 04:06 PM
andy044's Avatar
soft cotton cloth like it said
how do i take the headlight lense off, to get the broken glass out, ive looked in stickies and on the autozone.com site. i cant take the corner lights off, with no prob. juist the headlights are giving me trouble
doctorpullit
Oct 28, 2019 10:58 PM
doctorpullit
Mar 29, 2016 11:08 AM
magiconthetire
Oct 26, 2015 09:03 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Noela
Sep 26, 2015 08:22 AM
