Really bad gas mileage. I know I have bad fuel injectors but what about O2 sensors?
Do bad fuel injectors make the mpg really really bad, as in 10 mpg below the expected? What about O2 sensors? Will they affect gas mileage.
So I filled up my tank to 4.54 gallons and only ran 50 miles. That's about 11 mpg. But I drove in the city with many stop lights and stop signs going about 25 mph. I don't even drive fast. Always shifting at 2000 rpms.
The O2 sensor affects gas mileage. But if you are getting 10MPG, it is probably the injectors dumping fuel into combustion chamber. If that's the case, you are running rich and if you bought a new O2 sensor, it would probably die prematurely after being exposed to all that excess fuel. Fix your injectors.
BTW, how do you like the sound of your magnaflow muffler?
Originally Posted by Matt93SE
As he said... don't worry about the O2 sensor until you fix the injectors.
it's like sticking a band aid over a crack in the hoover dam- just ain't going to matter.
worse than that, if it's dumping fuel he'll ruin the o2 in short order.
I missed that one.and of course the cat will get destroyed too.
I sell injectors.and as an aside, I'm at 157 miles and I need to fill my tank less than an 1/8 left (closer to 1/16th left)
