Sponsored by:
Sponsored by: CARiD
Cylinder head and valve train miscellaneous information
Old Dec 16, 2004 | 08:39 AM
Stephen Max's Avatar
I'm creating this thread to document cylinder head information. I will link to it in the "useful threads" sticky.
If you have useful information, please post. Extraneous stuff will be deleted.
Old Dec 16, 2004 | 08:40 AM
From a post SR20DEN made:
I have been waiting for a good opportunity to realease this information and this appears to be it. The VK45 titanium valves are near identical to the VQ30 valves. The only thing that is different is the total length which can be adjusted with new shims.
VQ30DE Steel valve;
Face In: 36.0 - 36.3mm
Face Ex: 31.2 - 31.5mm
Stem In: 5.965 - 5.980mm
Stem Ex: 5.945 - 5.960mm
Length In: 97.32 - 97.82mm
Length Ex: 94.85 - 95.35mm
Valve seat angle 45º15' - 45º45'
VK45 Titanium valve;
Stem In: 5.972 - 5.980mm
Stem Ex: 5.962 - 5.970mm
Length In: 96.57mm
Length Ex: 94.50mm
The faces and the seat angles are identical. The stems are slightly different only because the expansion rates are slightly different between the metals. They're both classified as 6mm stems.
The only question that remains is the location of the keeper. If it's high enough on the Ti valve then there is no problem. If it's too low then custom retainers will be needed to make them work.
Old Dec 16, 2004 | 08:48 AM
SR20DEN:
VQ35 bucket:
Dia: 33.97mm
Height: 21.00mm
mass: ??
VQ30 Bucket
dia: 34.95mm
height: 26.03mm (no shim)
mass: ??
VQ30 shim:
mass: ??
SR20DEN:
All in grams
VQ35;
Intake Valve: 59.535
Exhaust Valve: 47.785
Retainer: 4.76
Lifters: 29.711-30.476
VQ30;
Intake Valve: 52.618
Exhaust Valve: 46.494
Retainer: 8.789
Lifters: 26.337
Shims: 15.706-15.819
Everything is listed except for the keepers/locks which should be identical.
Totals and differences (minus keepers)
VQ35 Intake 94.774
VQ30 Intake 103.563
Difference 8.789 (same as an entire VQ30 retainer)
VQ35 Exhaust 81.024
VQ30 Exhaust 97.439
Difference 16.415 (about the same as removing an entire VQ30 shim)
Same post in ounces
All in ounces
VQ35;
Intake Valve: 2.1
Exhaust Valve: 1.615
Retainer: 0.168
Lifters: 1.048-1.075
VQ30;
Intake Valve: 1.856
Exhaust Valve: 1.64
Retainer: 0.31
Lifters: 0.929
Shims: 0.554-0.558
VQ35 Intake 3.343
VQ30 Intake 3.653
Difference 0.31 (same as an entire VQ30 retainer)
VQ35 Exhaust 2.858
VQ30 Exhaust 3.437
Difference 0.579 (about the same as removing an entire VQ30 shim)
Old Dec 16, 2004 | 08:49 AM
SR20DEN:
VQ30DE Cams:
Pending
VQ30DE-K Cams:
Int: 8.55mm lift (gross)
Ex: 9.0mm lift (gross)
VQ35DE Cams:
Int: 9.5mm lift (gross)
Ex: 9.5mm lift (gross)
Old Dec 16, 2004 | 08:51 AM
japmaxse:
JWT 3.0 cams:
256 duration
10.5mm lift (gross)
JWT 3.5 cams
260 duration
10.9mm lift (gross)
Old Dec 16, 2004 | 11:24 AM
SR20DEN:
VQ35;
Swept: 583.0704
Total Chamber: 62.6957
CR: 10.3:1
Alternate
CR: 12.0:1
Total Chamber 53.0064
VQ30;
Swept: 497.9202
Total Chamber: 55.3245
CR: 10.0:1
VQ32:
Swept: 525.0499 (95.5x73.3)
+4.2978 chamber
CR: 8.8:1 (VQ35 heads, pistons, gasket)
VQ30DE with VQ35 heads/gasket
Swept: 497.9202
CR: 8.94:1
Old Dec 17, 2004 | 02:31 PM
TILLEYS99's Avatar
Lives in a 11sec maxima
NISMO
NISMO R Tune setup 262 degrees of duration .426" lift on the intake side
256 degrees duration on the exhaust side
NISMO's Spec 1 setup 276 degrees duration .433 " lift. The exhaust cam is 256 degrees duration with .413" of lift.
NISMO's Spec 2 cams are for the ultimate in top end power. 284 degrees of duration, and .433" lift on the intake side, exhaust cam features 268 degrees duration with .413" lift.
NISMO titanium valves weight INT (genuine 51.4g→NISMO 31.0g) EXH (genuine 46.8g→NISMO 28.7g).
Tomei
256 duration with 10.2 mm lift - offered in intake and exhaust cams
264 duration with 10.22 mm lift - offered in intake and exhaust cams
268 duration with 10.5 mm lift - offered in intake and exhaust cams
Old Dec 20, 2004 | 05:42 AM
VQ30 FSM page with valve dimensions. Go to page EM-67:
http://members.dslextreme.com/users/...esm/a32-em.pdf
Old Jan 20, 2005 | 08:46 AM
VQ35 cam specs:
http://forums.maxima.org/showthread....light=duration
Old Jan 23, 2005 | 08:53 PM
SR20DEN's Avatar
VQ Wizard
Taken from the Nismo page
http://www.poweraxel.com/nismo/news/...4/n040037.html
< High lift camshaft (Spec-1) >
1. INT cam: Enlargement in operation angle (238deg→ 276deg),
カムリフト cUp (9.5mm→ 11.0mm), central angle (125deg→ 138deg)
2. EXH cam: Enlargement in operation angle (240deg→ 256deg),
カムリフト cUp (9.5mm→ 10.5mm), central angle (112deg→ 120deg)
3. VTC operation (the 50deg) when pointing in crank angle,
As for overlap with VTC off with 8deg and VTC on 58deg
< High lift camshaft (Spec-2) >
1. INT cam: Enlargement in operation angle (238deg→ 284deg), カムリフト cUp (9.5mm→ 11.0mm), central angle (125deg→ 135deg)
2. EXH cam: Enlargement in operation angle (240deg→ 268deg), カムリフト cUp (9.5mm→ 10.5mm), central angle (112deg→ 115deg)
3. VTC operation (the 35deg) when pointing in crank angle, as for overlap with VTC off with the 18deg and VTC on 53deg
Old Mar 12, 2005 | 01:12 PM
michaelnyden's Avatar
has anyone tried swapping in the titanium VK valves and just re-shiming?
Old Apr 26, 2005 | 11:16 AM
royceso's Avatar
does anyone know what the vk45 bucket diameter is? also does anyone know of any oe buckets that are anywhere between 36 - 36.5mm OD that are a minimum of 21mm in height? i'm looking to put 2mm oversize buckets in my vq35, but i'd like to see if i can just use buckets from an existing car instead of getting them custom made. height doesn't matter i can machine it down to size as long as it's not shorter than stock. tia. also if anyone has specs on the vq40 buckets, i'd appreciate that too.
Old Apr 26, 2005 | 12:58 PM
SR20DEN's Avatar
VQ Wizard
Originally Posted by royceso
d i'm looking to put 2mm oversize buckets in my vq35
Umm... why??? That sounds about as usefull as putting nitrogen in your street tires.
Old Apr 26, 2005 | 02:17 PM
royceso's Avatar
it's for my twin turbo drag car. i'm getting cams w/ huge lift.
Old Apr 28, 2005 | 06:17 AM
TILLEYS99:
VK45 intake 31.5g
VQ35 intake 60.0g
VK45 exhaust 28.9g
VQ35 exhaust 46.8g
Both valves are almost the same size (need new buckets too shim right) the intake is .5mm smaller in the VK but still seats.
Total valvetrain weight loss of 556.8g which is 1.227lbs
Old Apr 28, 2005 | 07:14 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
Originally Posted by Stephen Max
TILLEYS99:
VK45 intake 31.5g
VQ35 intake 60.0g
VK45 exhaust 28.9g
VQ35 exhaust 46.8g
So, which springs would you use if you swapped the VQ35 valves with the VK45 valves? The VK springs, or is there something aftermarket?
Old Apr 28, 2005 | 11:30 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
VK and VQ30 springs are the same, so JWT VQ30 springs would work.
Old Jun 27, 2005 | 05:37 AM
Pathfinder VQ35
weight of one bucket, shim and retainer: 48 grams.
Old Dec 19, 2005 | 10:21 PM
Z350Lover's Avatar
TILLEYS99:
VK45 intake 31.5g
VQ35 intake 60.0g
VK45 exhaust 28.9g
VQ35 exhaust 46.8g
Stephen,
as you mentioned earlier with VK45 intake valve size... it is: Face In: 36.0 - 36.3mm, but the VQ35 intake face has around 37.15mm though.... and that's just over 1mm larger... will we still be able to use VK45 valves on VQ35? Many people told me that with 1mm larger, it is no possible to fit VK45 valves into VQ35... has anyone tried this out yet? I know they can fit into nismo cylinder heads without a problem since those heads are machined from VQ30 heads..
I need to know it asap as I am building my N/A motor now and just bent an exhaust valve with Nismo high lift valve springs at 7600rpm... apparently those valve springs from nismo are not stronge enough either... btw, I am using Nismo Spec 1 cams and running 11.5:1 compression pistons on carrillo rods.. and tune with motec m600.
So I am looking into valvetrains now, it will be great if I can just use VK45 titanium items instead of Ferrea items... and is it true that the VQ35 intake valve weights 60 grams instead of 51 grams? (apparently on nismo website, it says the standard intake valve weights 51 grams)..
Oh... Ferrea valve weights are here for VQ35 (standard size):
Intake: 53 grams
Exhaust: 42 grams
cheers,
richie
Old Dec 20, 2005 | 05:35 AM
IceY2K1's Avatar
Tilley put VK45DE valves in VQ35 heads, but it sounds like it wasn't easy.
Old Dec 20, 2005 | 05:43 AM
Originally Posted by Z350Lover
Stephen,
Sorry, I was quoting information that Tilley had posted in another thread, for archiving purposes. He is the man to talk to.
Old Dec 20, 2005 | 11:55 AM
Z350Lover's Avatar
So I guess going with Ferrea valve train will end up a lot cheaper and faster then...
Thanks for the helps!
richie
Mar 12, 2020 12:06 AM
hayne
Oct 5, 2015 11:53 AM
Tmax78
Sep 25, 2015 09:07 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
