My dilemma: 350z muffler or Dynomax Super Turbo
Old Dec 18, 2004 | 06:58 AM
Kevlo911's Avatar
Kevlo for President
Okay, the 350z/G35/FX all have the same style muffler, just different inlets. The muffler is 24x13in. So I know it will fit. If I get this one, I would get a 18x4in resonator.
Should I get that muffler or teh Dynomax Super Turbo muffler with dual outlets? If I get that one, it will be an 22x4in resonator.
I don't know which combo to get. I want it to be VERY quiet, but I want it to sound good. I have a ypipe so I know aftermarket is exhaust is gonna be louder then stock.
What should I do?
Old Dec 18, 2004 | 08:14 AM
Kevlo911's Avatar
Kevlo for President
Or should I just use a regular Dynomax Super Turbo muffler with one out?
Old Dec 18, 2004 | 08:18 AM
NmexMAX's Avatar
dot dot dot ...
That's what I used but with 2 resonators.One whrere the cat would be and the other after that before the 90 before the axle.
It sounds nice and quiet, though a bit louder than stock. I had it w/o resonators before, and yes, you WILL definately want those resonators on there b/c w/o them, it sounds horrible.
Old Dec 18, 2004 | 09:18 AM
Matt93SE's Avatar
STFU n00b!
Kev, I don't think the 350Z muffler will work for you because of where the inlets and outlets are.
(if you want it, I'll make you a good price on it. customer removed it after just 1000 miles on the car for a Stillen exhaust and asked me to sell it for him. It's been sitting in my back yard for about 6 months now.)
view from bottom:
http://www.mattblehm.com/stuff/IM001872.JPG
view from top, with exhaust facing away:
http://www.mattblehm.com/stuff/IM001873.JPG
rest of exhaust:
http://www.mattblehm.com/stuff/IM001874.JPG
Old Dec 18, 2004 | 09:24 AM
Kevlo911's Avatar
Kevlo for President
Couldn't I just cut the outs and ins off the muffler and then run my pipes so it looks like this
http://www.cardomain.com/memberpage/484611/3
Old Dec 18, 2004 | 11:05 AM
Maximan190's Avatar
thats the only feasable way to do it without smashing in the spare tire area
i had brainstormed this awhile back and the way the G35 and Z muffler (and most of the flowmasters) are set up is perfect..
memimage.cardomain.net/member_images/3/web/423000-423999/423813_2.jpg
look at my drawing and compare with the 1st pic matt posted youll see what i mean
i probably woulve had this done on mine already but i kinda ran out of and went into negative money with my motor job
Old Dec 18, 2004 | 11:45 AM
Kevlo911's Avatar
Kevlo for President
Matt, do you think it will work? How big is the resonator on the Z?
Anyone else? Should I even go for hte dual setup?
Old Dec 18, 2004 | 03:02 PM
Glude's Avatar
I think you should try the 350z muffler. Would be nice to see something different. Also I would like to see how it sounds on a 3.0.
Old Dec 18, 2004 | 09:48 PM
Matt93SE's Avatar
STFU n00b!
unfortunately, I don't think the 350 muffler will fit under there, but I'd have to see the car and the muffler again to see... tomorrow I'll try to take some meausrements for you, but I'll warn you- these mufflers are HUGE!
Old Dec 19, 2004 | 05:27 AM
Kevlo911's Avatar
Kevlo for President
It would be great if you could getthe measurments for me.
Old Dec 19, 2004 | 05:43 AM
WildmanAL's Avatar
For some reason I was thinking Pearlwhite2000 (I think his name is that) had 2 evos for duals. That is awesome though. I've never looked at this cardomain. Thanks Matt.
Old Dec 20, 2004 | 08:21 AM
Kevlo911's Avatar
Kevlo for President
Sorry, don't mean to seem so eager, but you have the measurements yet?
Old Dec 20, 2004 | 09:04 AM
Matt93SE's Avatar
STFU n00b!
Sorry.. forgot to get them the other day...
here's a crappy drawing I did in about 30 seconds...
www.mattblehm.com/stuff/muffler.jpg
all piping on it is 2.5" the little wedge on the front of the muffler is removeable and not included in those measurements. it sticks out another 5-6" in front of the muffler.
let me know if that answers the stuff you need.
Old Dec 20, 2004 | 09:42 AM
Kevlo911's Avatar
Kevlo for President
Do you think I can cut off the Inlet and outlets close to the muffler and then weld on new pipes so I can use it properly?
Old Dec 20, 2004 | 09:44 AM
Jeff92se's Avatar
I'm needing a caw
You have any roon inbetween the spare tire well and the rear of the bumper. The only way I see this working is if you mount the muffler the same way as it's in the Z but instead of the muffler being parallel to the ground, mount it perpendicular to the ground. Ie.. maybe fitting it inbetween the tire well and the bumber
Old Dec 20, 2004 | 09:46 AM
Kevlo911's Avatar
Kevlo for President
I can't mount in stock location and cut ends off hte muffler?
Old Dec 20, 2004 | 09:48 AM
Jeff92se's Avatar
I'm needing a caw
I suppose. But won't you have one pipe pointing towards the front of the car? You will have to extend that one quite a bit. If there is any room to do so.
Old Dec 20, 2004 | 09:53 AM
Kevlo911's Avatar
Kevlo for President
I want to do it like this
http://memimage.cardomain.net/member...11_69_full.jpg
Old Dec 20, 2004 | 10:17 AM
cardana24's Avatar
Blown
I still have this muffler if you wanna try it....it is heavy though so shipping would probably be high
Old Dec 20, 2004 | 10:26 AM
Kevlo911's Avatar
Kevlo for President
Well I don't want to spend money and find out I can't cut the ends off and run hte pipes like I want. So I will have to see what everyone says.
Old Dec 20, 2004 | 10:27 AM
Maximan190's Avatar
which is exactly the way i showed in the pic i drew... its the only practical way to do it without modifying the spare tire area
since the piping shoots out the muffler and bends immediately you would have to chop off all 3 pipes about 1-2" away from the muffler and weld on new piping from there
Old Dec 20, 2004 | 10:30 AM
Kevlo911's Avatar
Kevlo for President
But, it won't daamge the muffler by cutting hte ends off and running my own pipes like that will it?
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
