Sunroof Wind Deflector?
I'm thinking of installing a sunroof wind deflector. A friend of mine has one on his VW Passat,and he says it makes a big difference, cutting down on wind noise. I personally think they look a bit ugly, but I could live with the looks if the result is less wind noise.
Any experience?
Any experience?
In my dad's car, it does make a difference. It is up to you if you want it. If you are one of those who rarely open the sunroof and use it to get rid of hot air, then get it. Unless, if you are like me and open all the windows and blast the radio while driving, it won't make a diff.
It's worth getting.
I love the looks of the deflector from outside the car, and it is great for it's purpose of deflecting the wind. My only dislike is that it obstructs the view a little when looking out-from-in.
For a look, go here:
I took mine off because
it messes up the clear coat. I had a perfect outline of the rubber seal but the clear wasnt really damaged, just had lines. However, I couldnt have a normal tone conversion with it off at hwy speeds, so I put it back on.
I think the looks grow on you. I personally didn't like it at first, but since I heard negative comments about removing it (e.g. wind noise would increase substantially) I opted to keep it on. I think it looks "normal" now, for me. It has grown on me.
wind deflector
I had one on my last car and now have one on my 00 Max SE. I like the look it gives and the wind noise reduction. The only thing that I really don't like about it is, that water collects under there when it rains or snows and the water does not get pushed off the car because it deflects the wind. So when the water dries out, you are left with all sorts of road grime dried on to your sunroof.
Re: wind deflector
It's $45 from courtesy nissan or you can pick one up from a local dealer although he'll probably ream you for about $65.
It's really easy to install. They use the same part for the Pathfinder and 240 cuz it came with brackets for all of them.
This is an automobile, not a car. Cars come with deflectors,i.e. Kias, Hyndais, Mazdas, need I say more! Fine automobiles don't, Maximas, Mercedes, Porches, Bimmers, get the picture! I had one and took it off b/c it makes the car look unsporty and besides that it messes up the clear coat, I had to wet sand and buff the imprint out. If you want it you can have mine, it was on there for two weeks. It also reduces the amount of air that comes in through the roof!
Re: wind deflector
I know
Originally posted by Moonman
Well, I went for it. Dropped by the dealership yesterday,surprised to find the deflector cost only $87 Cdn, paid 20 bucks for install. Makes a huge difference in wind noise / turbulence. Thanks for the input, folks!
Forge277
Jun 13, 2016 09:26 PM
