Front AGX's shot, what to replace with?
Old Dec 26, 2004 | 05:24 PM
MaximaRider's Avatar
Hey all, as most of you know I've been running on AGX/Sprints for 2+ years now and one of my front agx's is shot and I have a feeling the other is on its way out as well. The rear ones still seem fine so I don't plan on changing them, would I be better off getting the front illuminas or replacing them again with AGX's? Where is the cheapest place to find either? My problem seems to be finding the two front struts sold seperately rather than all 4 together.
Thanx
-Arnaud
Old Dec 26, 2004 | 05:34 PM
VIP Maxima
illuminas for sure. havent heard of any blown sets of illuminas YET. there is a GD going on for them !
Old Dec 26, 2004 | 05:47 PM
deezo's Avatar
Pretty decent prices on this site. This is where I bought my rear Illuminas from.
http://www.sportcompactonly.com/prod...2167&catid=128
Old Dec 26, 2004 | 05:55 PM
Terran's Avatar
Not a GD anymore. Check the thread or maxmods for ordering instructions. They may be out so you may want to call to see when you could get them by.
I would agree. Get illumina's unless you want to swap out the whole suspension for coilovers. I know your car is no budget mobile.
Old Dec 26, 2004 | 07:29 PM
Thanx Deezo for the website.
Terran the thing is I don't want to purchase the whole set, I just want the fronts, my rear AGX's show no signs of age, while the front ones are just trash now. My car is turning into a budget mobile slowly but surely, starting to remove a few of the show mods and replacing them with OEM parts because in a year this will be my S/C four door beater :-)
Old Dec 26, 2004 | 07:30 PM
Damn they sell the fronts pretty expensive! I might be better off buying the whole set and keeping the rears until my agx's blow. Thanx for the help guys.
Old Dec 26, 2004 | 07:58 PM
Terran's Avatar
mmmmmmmmm...SC'd beater. I want one.
You can buy just the fronts. They are more expensive than the rears though. I want to say a pair for the fronts would be about $240, but I'm not sure. The deal should go on from now on so you could buy the fronts now and the rears whenever you need them and the total would still be $408.
Old Dec 26, 2004 | 11:04 PM
CKOTuHA's Avatar
On ebay they sell the front ones...
I thought AGX had a lifetime warrenty
Old Dec 27, 2004 | 06:49 AM
deezo's Avatar
I've seen the fronts for a lot more.
Old Dec 27, 2004 | 06:56 AM
mzmtg's Avatar
Minister of Silly Walks
How do you tell that they are shot?
Old Dec 27, 2004 | 08:05 AM
There is absolutely no rebound, you can tell when you hit bumps because it just slams the road on one side and glides over the otherside, my car has also been pulling to the side of the worn strut, leading me to believe its fully compressed all the time. I don't think KYB would warranty this because they have been on 2inch lowering springs for almost 50k miles on some of the worst roads in this country.
Old Dec 27, 2004 | 10:05 PM
Broaner's Avatar
2060lbs and falling...
The most common way to tell if its blown is to look for leakage. The only thing the a blown strut will do is effect the ride quality. It will not change the ride height. The spring holds the car up. The strut absorbs the road imperfections. It says right in the AGX booklet they do not warranty their stuff >1.5" drop.
Get Illuminas. You live in NJ that should be reason enough. VQuick has Illumina's/Tein(H Techs) and I have AGX/Progress. His ride quality is logically better than mine in the summer. In winter his ride is Cadillac like compared to mine. The AGX has no adjustability below 40 degrees. The only setting is, "Knock your teeth out". The AGX also only has adjustability on the rebound while the Illumina adjust both rebound and dampening. Illumina is far and away better. I certainly plan to upgrade to those if mine ever blow.
Old Dec 27, 2004 | 10:15 PM
CKOTuHA's Avatar
How would they know how low was your drop?
Old Dec 28, 2004 | 06:29 PM
Broaner's Avatar
They would probably ask what spring you were on and then they would like to have that verified by a reciept or some other proof.
Old Dec 28, 2004 | 06:37 PM
Ant96GLE's Avatar
what if your running illuminas on stock springs? They dont have to know your running aftermarket springs
Old Dec 28, 2004 | 06:48 PM
Broaner's Avatar
True but if there is wear on the top of the piston rod then they will know you are BS'ing them. They won't find that out till you send it too them and then they'll say your SOL. At which point you will be SOL cause you wasted $20+ on shipping. I know I'm being pessemistic but all warranty stuff I've tried has been a waste of time. Not with AGX in particular. Mainly CM.
Old Dec 28, 2004 | 06:50 PM
Ant96GLE's Avatar
CM/CE.. :shudders: never dealt with them, never will
Old Dec 28, 2004 | 07:44 PM
ny96max's Avatar
i love how people think illuminas are "so much better".... we should have a post set up 2yrs from now with people running illuminas on a 2" drop to see how they are holding up. Regardless of the strut brand they will eventrually go on you with a 2" drop. No aftermarket strut is designed to handle a car sitting 2" lower than it normally should be. Unless of course you buy shortened struts... but thats my .o2 on the whole illumina vs agx thing
back to the AGX thingy... one of mine went out after about a year being on Sprints... i just found a used set to replace both of them for $120 shipped and called it a day. Keep checkin the forsale forums, maybe youll get lucky
Ant
Old Dec 28, 2004 | 11:17 PM
Broaner's Avatar
I agree that the strut isn't designed to operate in that range. Nobody is questioning the longevity of the AGX or Illumina. What I was saying earlier is that the Illumina is superior in what it does through adjustment. First, the Illumina's don't get stiff in cold weather. Second, the adjustment on the Illumina alters both rebound and dampening while AGX's only alter rebound.
Old Dec 29, 2004 | 02:00 AM
JAY25's Avatar
My opinion, the AGX are crap. I seen them blow on regular 1.5 inch drop maximas. The AGX is just a adjustable tockico blue strut. Yes for the money they are an upgrade from stock.
You want a good strut that has been proven. I say you go with a Koni yellow. I lived in New Orleans and the roads are awful. With my 2 inch drop on cut coils they never blew. Thats why I have Konis on both of my maximas. Konis also come with lifeitme warranty unlike the AGXs. I dont know the story on the illuminas. I am not a big fan of Tockicos nor do I know their warrantee policy.
Old Dec 29, 2004 | 06:12 AM
mzmtg's Avatar
http://www.kyb.com/service/warranty.php#1
Old Dec 29, 2004 | 07:14 AM
deezo's Avatar
Illuminas makes the ride beautiful on H&R's. When I had AGX's, the car was stiff as hell plus the rears blew in no time.
FlaMark
Aug 21, 2015 11:06 AM
Samedi
Aug 12, 2015 01:54 AM
mls277
Aug 11, 2015 07:18 PM
kirkhilles
Aug 8, 2015 10:53 AM
