Where to put 6 strobe bulbs??
Old Dec 26, 2004 | 07:03 PM
TsingTsaoNYC's Avatar
I'm buying a Whelen 90 watt strobe kit with 6 bulbs and was wondering what was everyone's suggestion was on where to put the bulbs?
Old Dec 26, 2004 | 07:21 PM
MaximaRider's Avatar
Why not ask me? LoL, I had them in the clearance lights, headlights, and fogs, I also have four more in the rear in all the clear portions of my taillights. I never tried putting them in the red areas, but they are so bright they probably look like red ambulance strobes.
Old Dec 26, 2004 | 07:34 PM
1HOTMAX's Avatar
they come with 4.
strobes are ghey....you need lots of bulbs to look pretty dave. i had 16 bulb on the car at one point /right now i have 8/ 4 front/4 rear. ( the 4 in the wheels well blew out cause of rain/weather.....same with the ones under the car.
make sure you mount them internal.
Old Dec 26, 2004 | 07:36 PM
1HOTMAX's Avatar
i think you should mount them under the dash and add a disco ball
Old Dec 26, 2004 | 07:50 PM
Paradox Cefiro
in my I30 i have 2 in the headlights, 2 in the fog lights and one in each outter tail light.
Old Dec 26, 2004 | 09:26 PM
chenzarino's Avatar
Shiny Disco Ball
Old Dec 26, 2004 | 09:31 PM
ChristheNite
Kinda off topic BUT I ALSO have a Whelen 90 Watt Strobe kit available - i think arnaud let his go for $200, I could do beter then that if anyone is interested.
matty's Avatar
Originally Posted by 1HOTMAX
they come with 4.
There only ghey if ya dont need em..I was thinking of gettin em cause im a volunteer fire fighter...
-matt
Old Dec 26, 2004 | 10:45 PM
VIP Maxima
put them in the trash can
Old Dec 26, 2004 | 10:56 PM
Tyrexx's Avatar
Clearance lights, bumper lights, and rear turn signals
Old Dec 27, 2004 | 12:34 AM
Ant96GLE's Avatar
I have the whelen 90 watt kit too but I only have 4 bulbs right now... 2 in the front corners and 2 in the rear back up lights...
Old Dec 27, 2004 | 01:27 AM
Wisky97SE's Avatar
I have a basic ShoMe 65watt kit w. 4 strobes. headlights and corners. They work well, and have been through 1 winter and lots of bad weather without any problem.
Old Dec 27, 2004 | 07:38 AM
Slickismax's Avatar
I have a signal stat 6 strobe kit and a signal stat 2 strobe kit. One in each corner light, one in each front turn signal, and one in each red section of my R34 taillights.
Old Dec 27, 2004 | 08:03 AM
I let mine go for $200 because they come with 6 bulbs and I threw in my headlights as a freebie ;-)
Old Dec 27, 2004 | 04:46 PM
they come with 4.
When you gonna help me install these suckas???
Old Dec 28, 2004 | 10:20 AM
Dave I just remembered, for the switches that adjust pattern and speed your going to need "momentary switches" I had forgotten what they were called. Can anyone elaborate on the wiring scheme of the momentary switches, my memory is a little foggy and I don't want to give the wrong instructions.
Old Dec 28, 2004 | 12:55 PM
TJ_Max's Avatar
Paradox Systems Vendor
they have write ups, instructions online, i remember seeing them..its a pda, per model number...i have a shoMe kit, and i need help also, and im generally good at wiring.....
also....i need actual bulbs (strobes), ive got wires and powerpack....
are they universal? or do i have to buy "shoMe strobes"?
Old Dec 28, 2004 | 01:17 PM
Arnaud,
No worries man!! I got all the wiring diagrams from Whelen's website. Just a quick question, where did you buy your push button switches from?
P.S.
When you gonna install that smaller pulley??
Old Dec 29, 2004 | 11:07 AM
TJ_Max's Avatar
momentary switches as in, they have springs, so u can press them down, and they pop back up when u release em? just a regualr push button...
Old Dec 29, 2004 | 03:03 PM
Ant96GLE's Avatar
Yup thats what I have, just regular toggle switches.. momentary ones would be retarded... how would you leave them on if you park your car?
Old Dec 29, 2004 | 03:06 PM
I have toggle switches for on/off & momentaries to adjust speed/pattern. The toggle switches I picked up at radio shack for barely nothing.
Old Dec 29, 2004 | 03:28 PM
TJ_Max's Avatar
ok, i was wondering, is there a momentary switch, like a button u have to hold to strobe, and let go and it stops....now if u park ure car, u have a way to press th ebutton and twist and it stays down......hows that for a strobe idea? u cant accidentally leave em on and when u park u have to twist the button so it stays down and u strobe....
is there something similar out there?
im putting my strobes on....maybe a toggle switch and momentary in one circuit? i have no clue id like a switch like i just said above...
or even a switch u can slide a locking pin in so the button stays down and circuit stays closed
Old Dec 29, 2004 | 03:44 PM
Ant96GLE's Avatar
Yea momentary push button is to change patters but to turn them on and off you want a regular toggle type...
Old Dec 29, 2004 | 06:34 PM
waveridr85's Avatar
In your gauges and ontop of your steering wheel
Old Dec 29, 2004 | 06:35 PM
TJ_Max's Avatar
im not big on making a pattern wit strobes i cant even really see from in the car.....strobes are strobes to me....they flash, i never paid attention to patterns
BrandonCause
Sep 14, 2015 10:41 PM
kjlouis
Sep 14, 2015 11:22 AM
kadespraggins
Sep 14, 2015 12:04 AM
minsbang
Sep 11, 2015 08:48 PM
Justin Kroll
Sep 2, 2015 11:06 AM
