95 Nissan Maxima color code - where do I find it
Ok,
I need some touch up paint and I first need to find the color code...
Can anyone tell me where this is found on a 95 Maxima SE and what the code looks like (so Idont get it confused with another number)
Color Code... Where Can I find it?
Hello
I have a 95 Maxima SE and I need to find the color code can anyone inform me where taht is found and waht it looks like so I know that that is indeeed the color code?
Thanks in advance
Thanks in advance
first things first.. don't post the same thing in the general forum and the fourth gen forum.. pick one.. in this case, since it's related to a fourth gen, you probably should have stuck with just posting in here...
and since you just joined in dec 2004 (not that I am old school .org by any sense of the phrase), you should probably invest some time in reading the stickies / faq's up top there.. ya know the annoying threads that hardly ever change.. you'd be amazed at the amount of information contained within.. for instance, in the Fourth Gen faq stickied up top, the answer to your question is right on the first page..
have fun
have fun
please
please help ASAP
I looked on the inside of the drivers side door and all I found was
DATE:
GVWR #
GAWR FR #
AR #
and then there were 2 other numbers (one was under the scanning lines)
are any of these the color code?
DATE:
GVWR #
GAWR FR #
AR #
k
I read that stickied and it says
" Vehicle ID Plate located on the passenger side firewall under the hood."
I look under the hood on the passenger side and see nothing?
Where is the firewall?
Do I have to move something to see the id plate?
I don't think you have to move anything to see it.. the firewall is the back of the engine bay, look there, there should be a metal plate with your vin and other info there.. from that plate you should be able to get your color code..
hey
I have a VIN number plat right by the steering wheel but I dont see any other plate...
Why would I not have this? I just recently bought this car from the dealership...
Also Can you please tell me the color code for the goldish/tanish maximas?
color
My car is the smae color as these
http://www.cardomain.com/memberpage/599035
http://memimage.cardomain.net/member.../593458_64.jpg
http://www.cardomain.com/memberpage/236436
Please help ASAP
Please help ASAP
here are allt he body color codes
Please onlyrespond if you are serious
Body Color Code:
AL0 RUBY PEARL
AR2 CRIMSON BLAZE RED
AX5 NEW RED
BN6 STARFIRE BLUE PEARL
BT4 LAKESHORE BLUE
BV3 SATIN BLUE PEARL
CG2 PEBBLE BEIGE METALLIC
CP2 MAHOGANY PEARL
DJ2 BLACK EMERALD
DP0 DEEP EVERGREEN
DR2 SHERWOOD GREEN
EV0 SUNLIT SAND
FS0 SAGEMIST GREEN
KH3 SUPER BLACK
KN6 GRANITE PEARL
KT3 STERLING MIST
KV3 GRAY LUSTRE
LP0 PLATINUM IRIS
LS5 ROSEWOOD
LS6 CONCORD MIST
QN0 ARTIC WHITE PEARL (BASE)
QT1 ICELANDIC PEARL
Body Color Code:
AL0 RUBY PEARL
AX5 NEW RED
BT4 LAKESHORE BLUE
CP2 MAHOGANY PEARL
DJ2 BLACK EMERALD
DP0 DEEP EVERGREEN
DR2 SHERWOOD GREEN
EV0 SUNLIT SAND
FS0 SAGEMIST GREEN
KH3 SUPER BLACK
KN6 GRANITE PEARL
KT3 STERLING MIST
KV3 GRAY LUSTRE
LP0 PLATINUM IRIS
LS5 ROSEWOOD
LS6 CONCORD MIST
QT1 ICELANDIC PEARL
I dont have the plate
I dont the plate
I looked everywhere man
There is the stamped VIN and then on allsides I have the taped VINnumber but no plate
Can you tell fromt hepictures I posted? Those are the same color as my car...
Is there anywhere else this plate could be besides under the hoood?
Ok
All I see is the emission control label ,the engine serial number, the VIN # plate and the, VIN number( chasis number)
The plate we are looking for should be all the way to the back on the passengers side of the car right? - IF that is what we are talking about Im missing that...
Is there anyway you can tell from the pictures?
Mine is a 95 SE and same color as yours. For touching up, you would want to get the NS 00594 (Pebble Beige Met. CG2) by Duplicolor. Got it at Kraggen for $5.99. If you are coloring a larger area, you'd need the spray, but its a different number though. Look it up at the store's catalog.
ah2002
Mar 9, 2016 01:42 PM
xUNIxPanther
Aug 27, 2015 10:09 PM
District
Aug 15, 2015 08:23 PM
julian888
Aug 6, 2015 04:39 AM
