Is the Engine the same for the Auto & Manual ?
Old Dec 27, 2004 | 05:32 PM
alpicone's Avatar
Are there any differenced between the engine for the manual and auto Maxima's? I need to get a motor for a 97 max and I called up for one and he said he only had one for an auto not the manual.
So I need to know is there any dif between them? And is it something like on the VE where the dif is the intake manifold which can b easily swapped?
TIA
Old Dec 27, 2004 | 05:34 PM
mzmtg's Avatar
Minister of Silly Walks
They are all VQ30DE.
Old Dec 27, 2004 | 07:13 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
yes, engine is the same, I don't think the control units for the trannies are
Old Dec 27, 2004 | 07:18 PM
adithius's Avatar
The engines are the same.
Old Dec 27, 2004 | 10:26 PM
Broaner's Avatar
2060lbs and falling...
Engines are same. There is no control unit for the MT.
Old Dec 27, 2004 | 10:34 PM
newborn1281's Avatar
I wanted to change auto trayny to manual the engines the same the ecus are diferent so you could use that engine
Old Dec 28, 2004 | 06:37 AM
Kinger402's Avatar
Same Engine.
Old Dec 28, 2004 | 07:05 AM
konak85's Avatar
Manual has 50 more horsepower.
Old Dec 28, 2004 | 08:54 AM
Broaner's Avatar
Your post in incoherent but a 5Spd car will run with an auto ECU although codes will be present.
Old Dec 28, 2004 | 10:46 AM
alpicone's Avatar
I wasnt asking about any control units. I have to replace the engine in a 97 Maxima 5-spd. I just wanted to clarify that there is no differnce in the motors because when I called for one the guy asked if it was for a manual or auto, and said he only had for the auto.
Thanks for the info.
Old Dec 28, 2004 | 01:01 PM
Nismo3112's Avatar
Custom User Title
One thing that you must make sure you do is that the auto engine will have a torque convertor pilot bearing. YOU MUST PULL THE BEARING OUT, and replace it with a manual pilot bearing. If you leave the TQ convertor bearing in ther ethe manual pilot bearing will not fit, most likely making everything else not fit.
Old Dec 28, 2004 | 01:59 PM
alpicone's Avatar
Thanks! This is the type of info I am looking for. So are there any other little things that have to be done?
Old Dec 28, 2004 | 02:00 PM
Nismo3112's Avatar
Custom User Title
No prob. That is the only thing I can think of that is different. Other than that it is identicle.
MAXSE5SPD
Sep 17, 2022 04:00 AM
6spd4dsc
Mar 4, 2016 05:19 PM
Maxboy23
Sep 9, 2015 10:37 AM
03VQMAX
Sep 5, 2015 03:47 PM
minsbang
Sep 5, 2015 05:36 AM
