knock and 02 sensor gone bad, but no codes...
knock and 02 sensor problems HELP!
Ok i know the KS usually doesnt throw a CEL, but I hooked it up to a scan tool and in the pending codes I got the PO325 KS 1 Circuit Malfunction....
Im assuming I need to get a new KS right?
But I also had a PO155 02 sensor b2 s1 Heater circuit malfunction. You know this means the heater isnt working, so I may be entering in and out of closed loop while driving depending on Temps... I was just wondering if any of you think that this in and out of closed loop is also setting the KS....
Cause isnt the KS (is bad) code a PO334? Or am I wrong
Also, its 02 b1 s1 the o2 closest to the passenger side on the y-pipe (before the cat)?
I assume I should just replace both right
Thanks so much,
Jeff
Thanks so much,
Jeff
ballerchris510
Sep 23, 2015 08:46 PM
ballerchris510
Sep 11, 2015 05:29 PM
