parking brake boot question
Old Apr 23, 2001 | 10:29 AM
Cumalot's Avatar
I have a silver carbon fiber Razo parking brake. It looks really nice and match perfectly with my Razo auto shifter. However, the Razo parking brake wasn't a perfect fit for the Maxima. It was made for Honda/Acura. My problem now is that the parking brake boot doesn't seem to fit perfect with the parking brake. The boot tend to slip down a bit. I pulled the boot over the end of the handle a bit so it fit and look better. Anyway, after awhile, the boot slide back down a bit. I usually pull up my parking brake when I park and release it when I head out. That might be another reason why the boot is loose because I use the parking brake often. The stock parking brake held onto the boot nicely, it was a tight/perfect fit. Anyway, anyone know how I can keep the darn boot up?
Old Apr 23, 2001 | 10:35 AM
Daniel B. Martin's Avatar
Perhaps you could use an adhesive such as RTV Silicone, Welder, Shoe Goo, etc. You want something which will remain flexible after it is cured. Epoxy is not the right product for this repair.
Old Apr 23, 2001 | 10:37 AM
Justin95SE's Avatar
heres what i did.
i cut my stock shifter and the boot around that kept slipping down because it had nothing to grab around so i wrapped a generous amount of electrical tape around the actual stick to hold the boot up, this worked and hasnt given me any problems.
Old Apr 23, 2001 | 11:45 AM
jiaxima96's Avatar
I used a piece of double-sided sticky tape for the boot to stay in the handle groove. It works perfect to me. Before I did that I found it was not that easy for the boot to slide down, but it was a little too loose, and once in a while it slid down.
Old Apr 23, 2001 | 12:20 PM
Cumalot's Avatar
All are good ideas. Thanks guys. I'll try them them all and see what works.
sctludwig
Sep 1, 2022 01:32 PM
BkGreen97
Apr 2, 2016 05:47 AM
cruce91
Sep 20, 2015 10:23 AM
crazyespn
Sep 3, 2015 01:30 PM
Johnny9595
Sep 3, 2015 05:18 AM
