Fan turned on => high pitched squeaking noise
Sounds as if the fans behind the vents need to be re-oiled. How about spraying some WD-40 on them? Worried about stinking up the car, though. Obviously, I'd probly have to pull out the vent covers.
Same problem here. bump for the answer.
Most likely is a bad blower motor. The symptom is noise at low fan speed, loudest at speed 1. Noise typically goes away at speed 3 or 4. If fan is left at speed 4 for about 15 - 30 seconds, then no more noise (for a while), even if fan speed is set back to speed 1 or 2. Noise is also louder in recirculated mode.
The only fix is a new blower motor. Nissan has a TSB to put a plastic cover on the motor to reduce the noise. Don't waste your time with the TSB. It does not help at all.
Note: I took the blower motor apart to reoil it. Did not help with the noise.
Nissan OEM part is about $130 + $13 shipping (www.nissanparts.cc). Very easy to install yourself, about 30 minutes.
Justin Kroll
Sep 2, 2015 11:06 AM
