Do I need to replace my MT fluid for the 120k service?
I use the copper plugs but many prefer the platinum. As far as the manual trans, some say Redline, some say Amsoil. I used Amsoil, I like it a lot. It feels much better than standard oil. You'll need 4.5 to 5 quarts. I pulled the reverse switch to drain mine. If you do the same thing be careful with it, it can break, it's plastic. ONLY USE GL-4, NOT GL-5. Several write ups and my research suggest GL-4 ONLY. Amsoil does have it, they call it marine lube or something now but they do still have it.
Oh, and don't force the switch back in. It has an O-ring on it, make sure it stays in place. When you remove the switch the oil comes out in a hurry. Have a big pan handy. By the way. I think a gallon bucket is all they sell the amsoil in. It's around 30 bucks. Redline may sell quarts, not sure. Ask around about the pros and cons of each brand. If I remember correctly the redline works better in cold weather but the amsoil gives better wear resistance. That's what I read somewhere but you may want to look into it, I may be wrong. I'm sure a good synthetic GL-4 is better than non synthetic.
stock fluids last for about 60K right? I'd assume it can go atleast 60.
ih regular engine oil last 3K and syth can go atleast 6K then I Know tranny fluid isnt the same as engine oil but It should be able to do atleast 100K ?
Mrbizness1
Aug 18, 2015 08:43 PM
scarletsosa
Aug 17, 2015 09:09 PM
