Changing Fog Light Bulbs on a 2000
Originally Posted by DUSTR 71
Thanks for the link to the Housecor site. Seems like a lot of work just to replace a bulb!
Need to replace a burnt out bulb on my 2000 Maxima SE. How do you get to the bulb to change it? The link in the How To section here does not work.
Help!
Help!
Take off the headlight and access the fogs from the top might be easier than taking off the splash guards from the bottom. Just a tip. I haven't personally changed the fog bulbs, just noticed the assembly itself is easy to get to when the headlights are removed.
i did it last week. you need to take off like 3 screw bolt things that hold the plastic covers on. after you can see the assembly remove the screw thats on the bottom of the assembly. unplug the connector, twist the cover off, pull the metal clip away to access the bulb, unplug the bulb then pull up on the bulb. Housecors site helped but things were a little different.
another thing housecor's howto doesn't state is how to disconnect the wiring harness that's attached to the frame. if i remember correctly there should be a little button in the middle that you have to press down the a flat head screw driver and then pull the clips apart.
vingodine
45
May 21, 2016 12:46 PM
Viralkill
Aug 17, 2015 10:54 AM
MikesChevelle
Aug 6, 2015 11:36 AM
