high flow cat
high flow cat
what would be the difference between this cat and the stock http://cgi.ebay.com/ebaymotors/ws/eB...category=33629
The difference is basically with this one you won't pass emission inspection, with the stock OEM cat you will. I'm not sure if you gain any HP tho. Anyway Soonrfan has something like that..
http://forums.maxima.org/showthread.php?t=368931
Read up..
Read up..
that is not a cat..its a straight pipe like i have.
but if it was a "hi-flow" cat then....
three-way catalytic converters on todays cars use a honeycomb structure. they are less restrictive then the older kind that used ceramic beads.
bottom line...the "hi-flow" cats are not much less restrictive then the stock one so i feel that they are a waste of money.
Originally Posted by E55AMG2
The best high flow cat on the market is the warpspeed metal substrate cat. Flows as well as a test pipe, and will pass emissions in most states. Only problem, its $175
FYI: Make sure your car is running for awhile so that the CAT is operated at an optimum temperature.
TallTom
57
Oct 14, 2025 05:16 PM
