Doing my front brakes.... NEED HELP!
My car is on jack stands as Im typing. the front calipers wont fit the new brake pads. For those who had done it what do you use to compress the piston? Thanks.
You don't need to remocve brake fluid usually, only in some cases. If you do, just open the master cylinder.
They also have special "tools", it's called a brake tool, basically a half-moon shaped c clamp, works wonders for the job, but since your car's on jack stands, you'd probably be better off with a normal c clamp, if you don't have one, you need to unscrew the caliper bleeding nipple a bit, and use a crescent and push the holy he// out of the caliper to go back, I had to do this the first time I did my brakes.
FYI :
No, the brake tool I'm referring to is not the brake tool that is used for the rear calipers.
FYI :
If you're not already done...What i've found works really good is you bolt the caliper back up with the old pads in place, and using a BIG flathead screwdriver or pry bar, wedge the flat end between the inside pad and the rotor (access through the hole in the top of the caliper) and pry gently. It won't damage the rotors and works the *****. Good luck
Hdnseek
Sep 9, 2015 05:55 AM
