Lowering Springs..?
I’m a huge fan of the Eibach springs; I have had them on several cars including my A4 which I had b4 the Max; I am having the Max lowered this ( or next ) week from a place in South FL called California Customs, the total cost including the alignment was just over $600.00. its probably a little over priced, but these guys have a great reputation and they know what they are doing, that’s worth the extra money.
GET YOUR CAR LOWERED AND ALIGNED AT A CUSTOM SHOP!!!!!
As far as handling, I had a mustang and the Audi, both with Eibach’s the ride was just perfect… not so stiff that you felt every bump in the road, but tight enough that the steering response was, especially around corners, noticeably improved… in my opinion, you can’t go wrong.
Warranty is a good questions, if you go to eibach.com I’m sure you can find that info..
I've always been told by dealerships that the warranty is only voided on the suspension, but if something else happens and it was caused by the car being lowered you could run into problems.
I was just running all of my cars through my head and I've never had a car with stock suspension, I have some kind of addiction!!
3 raised trucks, 1 lowered and 2 lowered cars...
Originally Posted by BigCat44
Do the springs yourself if you have access to a lift, really easy to do job and no you don't have to do a wheel alignment if you don't want to.
Originally Posted by jonniewaka
some body in my town try doing oil change at home with a jack and killed himelf instanly..the jack came down on him while changing his oil filter.s
Originally Posted by Ammi
You don't need a lift. You can just use jacks at home.
It's a lot easier to drop all the wheels and do it on a lift, not that you need a lift but waaaaayyy more convenient. Also I'm pretty sure you need a spring compressor though this was used on a previous car not the Maxima. I wouldn't see how anything would be different.
How much does a garage charge for changing the springs? It may be worth letting them do it if its not much. Course I do my own work but I have power tools and a compressor, but no lift.
I just like to work on my car so time goes by really quickly. It's fun but if you are pushing for time, maybe it's better if you have a shop do it
Originally Posted by serpentkilla
You don't need a spring compressor, just loosen the center bolt before the other 4. It will compress itself, you will hear a poping sound. After that loosen the 4 bolts and your good to go.
You remove the strut by first taking out the two large bolts at the bottom, then remove the three nuts at the top of the strut tower. Once you have the strut/spring assembly out, you can use the spring compresser to dissassemble the rest of the unit. Do not remove the nut on the end of the strut shaft untill the spring compresser is in place.
You're welcome.
Originally Posted by NAGADOIT
they arent under THAT much compression!
To your Mama: Yes they are.You will need to compress the stock springs a good 2 inches before they can be removed from the strut. I know this from experience: I installed the Eibachs on my car.
Hey Tek-Niq, Thanx for the "ups".
Here's a link to my site, if anybody is interested:http://www.cardomain.com/id/04redopmax
The thing I want to stress is safety. Be smart when you are working on your car. Always use jack stands to support the car when you are working under it or even near it. If you don't have the proper tools or equipment to work on struts, get a pro to do it.
Bzzzzzz! WRONG!! You do need to use spring compresser on the front struts. Trying to remove the springs without a compresser could result in injury (or death). The stock springs are compresssed and are under tremendous pre-load. They are held on the strut assembly by one nut that threads on to the end of the strut shaft.
You're welcome.
You're welcome.
Yeah I am kind of spoiled living on base and all, we have a garage called the Auto Hobby Shop. They have them at most bases and you can rent the bays or lifts or paint bays and do all of your own work. The have licensed mechs running around helping but most of the time they do free-lance work to make some extra money! I have used a spring compressor everytime because that spring is under very heavy loads and even if you yourself stay safe, something about physics just makes me not want to put that much strain on one bolt and the tech manual doesn't specify any deviation in the removal or replacement of the springs.
I'm not gonna get into a pissing contest with you, i say you don't need a compresser and you dont. If you lossen that one bolt first without lossining the 2 on the bottom, where is the spring gonna go? If you try this with the strut assembly out of the car then your asking for it. I've done this numerous of times once with the compresser but that s*** took to long. You have your methods and i have mine. Don't act like you know it all.
Ok pops, why don't you go and rest your old ***. How can you sit there bash me about something you've never done. Just drop the ****, cuz this is not helping the original poster and i don't want to get of on the wrong foot with you. I don't even know you. Later mr know it all
MaxLvr21
Oct 17, 2015 12:11 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
