slave cylinder replacement
after my clutch resivour completely draining out the other day and then putting in new fluid and bleeding it, it is working excellent. i still know that the hose with the bracket on it has a leak which caused my clutch 2 have no pressure in it.
i brought it 2 my mechanic and he told me that the hose should def. be replaced but while im down there it would make sense 2 replace the slave cylinder also. my car does have 157,000 miles on it so the slave is prolly worn out.. he said the parts and labor would cost around 200 bucks. i am saving the money as we speak. how can i tell if my slave needs 2 be replaced?? is it worth it 2 have my mechaic order the parts or should i get them? if so where can i get them???
is 200 expensive for the slave, hose, and labor? is it easy 2 replace the slave myself?
you should defiantely get them you can most likely find a better deal than your mechanic
check for sale forums
www.car-part.com I know they should have some
check you junk yard
jerryrome nisaan
local stealer
hopefully you would have found one for a good price before you get to the bottom of that list.,
best way to check for slave leaks, is to poke around in there look for wet spots, or their is a write up on how to replace slave cylinder, not that hard at all, you could probably get away with doing it yourself for around $70, others on here have.
I think $200 is way too much, check around.
check you junk yard
jerryrome nisaan
local stealer
http://www.car-part.com/cgi-bin/search.cgi
25$ for the slave clyinder? i feel like this site wont include everything 2 get it installed. i also need that hose
I'm also in the same boat. I have a very slow leak where I have to add more fluid in the clutch reservoir every month or so. I looked under today and I do have a leak from the master cylinder, area is wet. I am going to get the master, slave, and the lines in between replaced (30% off from a hook-up). I'm getting parts, my buddy at the tranny shop is doing the work for me for free.
BTW, that car-part site sells used parts? What's the point in buying used master/slave cylinder parts? Isn't it better to get them new for obvious reasons?
) so getting a used one for a dirt cheap price could be the fix he needs and it works as good as a new one.
The slave has very few moving parts. Only the seals are the area of concern. If used in conjution with DOT-5 fluid the seals will NEVER wear out. Why throw all these perfectly good parts in the landfills to waste even more of Earth's valuable resources.
vingodine
45
May 21, 2016 12:46 PM
