Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
? about synthetic trans fluid
Old Jan 26, 2005 | 11:40 AM
newdiamond's Avatar
I have 136k on my 95 Auto, and I recently took it in for routine transmission service. On the work record I was given when I picked up the car it said they had put in synthetic trans fluid. Know I have noticed that the trans fluid is shifting differently, especially on the 2-3 shift, the RPMs actually briefly rise during the shift, and it seeems to take longer to shift than b4. Should I be concerned ? Should I take it back and have them take out the synthetic ? Your feedback appreciated...
Old Jan 26, 2005 | 11:53 AM
mzmtg's Avatar
Minister of Silly Walks
Somehow, your trans is now slipping on the 2-3 shift. That's really not good at all.
Old Jan 26, 2005 | 03:34 PM
Ant96GLE's Avatar
Thats what happens when you change transmission fluid on a car with high mileage... Sounds like your going to need a rebuild...
Old Jan 26, 2005 | 04:52 PM
bladerunr's Avatar
I'm very surprised that they put in syn without your approval. Typically, syn is more expensive, hence the customer approval. I had a 94 that I changed the tranny fluid at around 150K. I put in cheap organic stuff with no problems. I would take the car back, verify what they used and have them put in regular organic stuff.
Old Jan 26, 2005 | 04:58 PM
Ant96GLE's Avatar
Synthetic wouldnt cause his transmission to go bad, hes 1,000,000X's better by putting in synthetic than regular oil, especially in the transmission.
Old Jan 26, 2005 | 07:41 PM
mzmtg's Avatar
That's what happens when you spout old myths
Old Jan 27, 2005 | 11:48 AM
newdiamond's Avatar
I just talked to the the auto shop that did the service, I am going to take it in tomorrow and the service advisor is going to ride with me to see what i'm talking about. of course he gave me the whole deal on 'if the trans had never been serviced b4 then changing the fluid causes problems, etc.' BTW the synthetic fluid cost $70
Old Jan 27, 2005 | 04:48 PM
bladerunr's Avatar
Ideally, you shouldn't have problems changing at that mileage or using synthetic. Your tranny and ECU may just need time to adjust to the new cleaner fluid. Remember, the new fluid will have different properties than the old dirty fluid. I would look at the specs of the synthetic and compare that to the owners manual, just in case.
user 11122324
42
Jul 18, 2022 03:35 PM
mclasser
22
Nov 12, 2020 01:58 PM
Fbana41
Aug 29, 2016 12:18 PM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
