what clutch kits everyone using
well popped my five speed in my maxima no big deal i bought it with the trans that way.did ok by me car has 170.000 miles!!i ordered the replacement trans and figurerd time to get a clutch kit found one from compitition clutches.its there gravity series clutch??just wondering what you guys are using,and what good oil should i use to fill it.
clutch depends a TON on what you are looking to do with your max - lots of guys are using the 4th gen disk and pressure plate from the 5th gen for a nice stock setup - then there's boosted applications too. Redline synthetic gear oil is the best - especially since you are in CT with the cold winters non-synthetic will feel like sludge.
im planning on exhaust stuff,already did the intake.maybe a computer later.hey i see your up in mass.thats where i bought the trans. from.a yard in berkley ma i think it was.i bought the competition clutch kit.went to there site they seem to be a pretty good company.hows your weather up there you guys got hammered last weekend!!
i payed about 270.00 plus shipping for the stage 1 gravity kit.i got it thru nopi.on there site it is 319.00 plus shipping.www.competitionclutch.com
it says for agressive drivers so that sounded perfect for me.thanks for the input guys!!
I have an ACT, it grabs real hard and the pedal is really really stiff. I like the feeling of it, but I guess it would depend on how you like it. People say the ACT chews trannys but I don't believe it, its only how you drive.
i would just stay stock..if you are not putting out alot more pwoer than stock you do not need anything eles. Driveablility on the "performance" clutches sucks compared. I mean it is bareable but not as comfortable. I had an ACT but went back to stock and i like the stock clutch much better.
Definatly get the ACT Stage one clutch, i got that on mine and i could not have been more satisfied with the performance of the clutch. Normal driving is very smooth, but if you want to get at it, it will handle anything you throw at it, and it
barks 3rd sometimes 4th gear
Originally Posted by Gmahoney
Ive been wanting to do a new clutch maybe and maybe brakes... So ppl like the Oem 5th gen setup??? How much is that looking to be in prices? I would be interested in that.
Originally Posted by Jeff92se
Use any quality oem type or mild upgrade you want. BUT WHATEVER YOU DO, DO NOT USE THE NISSAN KEY VALUE CLUTCH KITS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
. I wondering if the two bad experiences I read about might have been because of a bad break in period or non resurfaced or replaced flywheel.
Originally Posted by Batxel
Are they really that bad and what makes them worse than every other clutch ever built. I all I read is
how come no one talk about spec here?
dude, spec rocks!!!
i got spec stage 2, it's got very soft and nice engagement and doubled featherlight pedal feel. first time driving it after installation, i couldn't even do my 1st gear right. it engages right after you let off the clutch pedal.
plus, my tiny girlfriend didn't like the hard clutch feel, so changing it to spec 2 wins both sides of the table
i combo-ed the spec stage 2 with the stillen 5lb flywheel. it revs much faster than stock, and the gear range increased. i can go pretty smooth from 15mph-up with 4th gear. with stock flywheel, it had to rattle out to catch it.
dude, spec rocks!!!
Just order 5th Pressure plate..............
Originally Posted by Mishmosh
Those are certainly valid points as they affecto performance a great deal. However, just the fact that Nissan sells these limits of the Key Value kit. It should be noted that labor is a large chunk so it's not worth saving a few buck to gamble on the Key Value.
I just order 5th Gen Clutch cover and the rest 4th Gen parts, each dealership I talked tried to sell me a Key Value. I think I have a Key Value on the car now. In a year of ownership I have only spun the tires a couple of times. (alothough I have tried) The good thing is the weak clutch was more forgiving with the tranny I am sure if I had a strong clutch I would have chirped the tires a few hundred times by now. I have had Centerforce Dual Friction never slipped but I was not happy with it. If guys have gone to the track 120+ times and have not had the stock clutch slip I feel good about stock.
I've been running exedy stage 1 for 20K now w/no problems,from Clutchmasters CA. Ebay around 125$ shipped w/unorthodox udp & aasco motorsports 5lb. flywheel talk about fast reving & low end tq improvment. I'm also using redline mt-90 in my trans & that is the fluid I would recommend, i live in slc ut and the winters are pretty cold, this fluid makes shifting alot smoother when vehicle is cold.
Originally Posted by ivolley
I read you previous post, so I went ahead and order a 5th Gen PP. Does it feel any different than the 4th gen (grab harder) or is it just stronger (longer lasting)
Pat
Pat
Apr 16, 2020 05:15 AM
Pied
Sep 26, 2015 03:29 PM
