how do you get these things off?!?!
hey how do you get off the cover to the speakers on the back of a 98? i tryed to get them off put i ddint wanna break anything, do you have to go through the trunk or what.. someone write back quickly.. thanks
You have to take out the whole back seat.
Remove the bottom cushion by undoing the two latches under the front edge
Remove four 10mm bolts from the upper cushion, two at the very outer lower edges and two under the trim when you fold down the arm rest
Then lift the upper cushion off its hooks and out of the car
Then you have to remove the side trim, the big pieces that the seat belts poke out of on the C-pillars, just pop them off carefully
Then carefully pop off the rear deck trim...the grilles are attatched to it
There...simple
There...simple
for more indepth.. i think performanceIX has it in their "how to" section. check it out www.performanceix.com
bigfrank
Oct 1, 2015 12:51 PM
