Knock sensor harness
Old Jan 31, 2005 | 10:05 AM
blueice's Avatar
Hey,
I brought my car to the mechanic and he pointed out that the wire leading from the knock sensor to the connector on top of the engine was sliced. This was the problem, not that the knock sensor itself is bad.
He tried ordering the knock sensor wire, which goes from in the middle of the engine to that gray connector on top of the engine. 2 times the wrong part came because the connector didnt fit correctly on the wiring harness. I went to the Nissan dealership and they told me that nissan doesnt make the part anymore and I have to order a new harness for 90 bucks from an altima or something and then I have to buy the other wire for the altima to make it fit.
What is the correct part number I need for the wire for my 1996 maxima SE that goes from in the middle of the engine to the top of the engine? How the hell do I unplug the connector in the middle of the engine? I tried doing that and I simply cant get my hand in there to unplug it? Please help I want my horespower back!
Old Jan 31, 2005 | 10:18 AM
mzmtg's Avatar
Minister of Silly Walks
Your "mechanic" is incorrect. That wire is not supposed to be connected to anything. The sensor grounds through the engine block, not the harness.
If you trace it back, there is only supposed to be one wire that connects from the car to the sensor, even though there are two in the harness.
Old Jan 31, 2005 | 10:35 AM
knight71's Avatar
I ordered mine through :
www.jerryromenissan.com
part # is 2407931u01 it costs $17.56
Old Jan 31, 2005 | 12:50 PM
UncleMax98's Avatar
You have to remove the knock sensor to detach the cable from the KS. There is a metal clip that has to be removed first.
ballerchris510
Sep 23, 2015 08:46 PM
homeofbacon
Sep 23, 2015 07:17 PM
ac max 92
Sep 17, 2015 07:35 AM
