Car will not start, no dash lights turn on w/ ignition..Need help ASAP Please!!
Old Feb 11, 2005 | 10:32 PM
95CustomMaxima's Avatar
Alright- Tonight I went out with my car and met up with some friends at a parking lot..I parked my car but left the keys in it on the accessory mode(radio on) for about 5-10 minutes..
I then got back in my car and the radio was still on, so I went ahead to start it and absolutely nothing happened.. I tried it again and now nothing would work, No dash lights, radio, clock... I havent been able to get Anything out of turning the key anymore.. I figured it was maybe a bad connection or something, but no luck their. I had to get my car towed back home by a friend after 3 hours of diagnosing it without any luck.. I checked fuses, connections, used a Volt Ohm Meter and the battery and starter where getting good voltage..
I am now to the point where I feel that it's ignition related.. maybe the switch or something.. So basically nothing happens when I turn the key, No dash lights, radio cranking, fuel pump..anything... Although my headlights, interior lights work fine?
Please someone help me out, Its 12:30 right now and I have to be to work by 9:00, so any help now or anytime is GREATLY APPRECIATED!!!!
Thank you,
-Nick
Old Feb 11, 2005 | 10:39 PM
BTW I had checked the battery for power and it was fine (new Optima Red Top).. It just seems like the ignition switch is not giving a signal when the key is turned.. I have removed the ignition switch covers and havent noticed anything out of place... No prior problems until tonight.. No signs of hard starts of anything before this..
-Nick
Old Feb 12, 2005 | 05:50 AM
bump...anyone??
Old Feb 12, 2005 | 06:03 AM
njmaxseltd's Avatar
Ignition switches are known to go bad....
Old Feb 12, 2005 | 06:57 AM
klymkow's Avatar
sounds like the ignition switch......
only about $30 if I remember right. can dig out the part number if you want it.
takes about 1/2 hr
Old Feb 12, 2005 | 06:58 AM
Yes, I have had to replace my ignition switch about 2 years ago.. But this isnt the symptons that it gave me when it went bad.. The car just wouldnt start then, but all the dash lights would turn on when the key was turned.. Now nothing happens, but the ignition switch is the only thing I can find feasible now.. Does anyone know if you can get a ign. switch at Autozone and such.. My Nissan dealers are closed today for the weekend.
Thanks,
-Nick
Old Feb 12, 2005 | 07:00 AM
Also does it seem right that the ignition switch would just go without any symptons prior? I mean the car has been absolutely perfect, no hard starts or anything and jjust know this happens..
-Nick
Old Feb 12, 2005 | 07:59 AM
klymkow's Avatar
If wiggling the key around alittle bit in the switch does nothing, it's probably not the switch - especially if it's only 2 years old.
It could be relays, alarm system, fusible links. If you have an FSM, look under the starting system. I'll look and see what I can dig up.
Old Feb 12, 2005 | 08:21 AM
Wiggling the key does nothing... I've called everywhere and no one can get the switch until at least Tuesday.. If you could look in your FSM that would be great! I found a wrench that was laying in my engine bay right by the starter, I have no idea what is was doing there... I am now starting to believe it has something to do with that.. There were no arc marks on either the starter or wrench. I'm going to try looking at the starter relay next.. But I dont understand how that would affect the dash lights and such, but I dont know..
Any help is greatly appreciated.
Thanks,
-Nick
Old Feb 12, 2005 | 09:46 AM
klymkow's Avatar
if you send me your e-mail address, I can send info from the FSM that should help you out.
Old Feb 12, 2005 | 01:03 PM
motocross416's Avatar
It sounds like a fusible link. My car did the same thing. Pull the cover off the fuse box beside the battery, put your key in the on position and wiggle the ignition fuse. There are a few different fuses under there, try any associated with ignition or power. The are alot bigger than a normal fuse, you should be able to see what I'm talking about. If it is the fuse loose, you will hear clicking and your heater kick on when it makes contact. If the fuse is blown, you could stick a wire inside the fuse, which basically bipasses it, but allows you to drive the car. I hope that can help you.
Old Feb 12, 2005 | 02:03 PM
Rotncarcas's Avatar
Similiar Problem...?
My car is having a simliar problem. I turn the ignition and the lights dim, but SOMETIMES the starter will not crank. About 50% of the time the starter cranks, if not i release the key and try again, this time it cranks fine.
Replaced starter, no change
Put a relay in the ignition wire just short of the starter, so if any signal goes through the wire, a direct 12v from the battery is sent instead. This changed nothing.
I guess my ignition switch is bad?? Anyone?
95 Maxima GLE
Old Oct 18, 2014 | 12:33 PM
maximacarlover's Avatar
Car will not start wants to but will not
I have a 1999 nissan maxima that will not start it tries to start but nothing and dash lights not coming one everything like radio and door buzzer works
Old Oct 18, 2014 | 07:45 PM
Nightstalker61O's Avatar
I would pull out the switch and try turning it with a screwdriver. If you need an ignition switch, let me know. I can get you one.
Old Oct 18, 2014 | 09:38 PM
DennisMik's Avatar
What do you mean by "tries to start"? Does this mean the engine cranks over but doesn't start?
When you first turn the key to the ON position, do you get the lights in the instrument cluster (oil, battery, etc)?
Old Oct 19, 2014 | 02:08 AM
dwapenyi's Avatar
The starter might be stuck. Get a hammer and long screwdriver to tap the starter gently, then try to start the car.
Old Oct 19, 2014 | 02:19 AM
NATS may have struck and you've been immobilized. Tell us what the security light is doing as you're cranking.
Old Jun 21, 2016 | 03:07 PM
piratefilmco@gmail.com's Avatar
same thing 2005 nissan xterra
same exact circumstances left key in while doing a spark plug change got in dash came on, turned key everything went black/blank, no power no blinky security light. did you find a resolution?
Old Jun 21, 2016 | 04:06 PM
JvG's Avatar
JvG
Is yours a 1999?
Old Jun 22, 2016 | 01:36 PM
DBear's Avatar
95 Maxima GLE
My first guess would be battery. What voltage is it showing? And check the connections and ground, and make sure they're clean and tight.
Old Aug 30, 2017 | 08:00 PM
RoroandRobin's Avatar
I have the exact same problem as Nick. Can anyone tell me how this was resolved. Bought a new ignition switch and that didn't work.
Thanks,
-Nick
Old Aug 31, 2017 | 08:18 AM
DennisMik's Avatar
There are many things that can keep the car from starting. What fixed one person's problem, may not fix yours. You found that out with the ignition switch.
Instead of throwing parts at the car, diagnose the problem. Here is a link to guide you.
https://maxima.org/forums/5th-genera...rt-thread.html
Old Sep 3, 2017 | 02:47 PM
After examining the car we noticed that one of the belts is missing. It's the one at the bottom near starter not sure what it's called. Could this be the problem? Also what is the name of this belt so I can get another one
Old Sep 3, 2017 | 03:12 PM
CS_AR's Avatar
Serpentine drive belt. It's the outer belt in this video. The video covers the power steering and serpentine drive belt.
Old Sep 5, 2017 | 12:28 PM
DennisMik's Avatar
Well, I guess I have to accept the fact that one of your belts is missing.
However, your statement "It's the one at the bottom near starter" is grossly inaccurate. The belts are on the passenger side of the car and the starter is on the driver side. Also, the starter is not at the bottom of the engine, it is about 3/4 of the way up.
You were looking at either the alternator or the air conditioning compressor.
Old Jan 27, 2022 | 03:39 AM
Jcg's Avatar
Jcg
I had a similar problem I turn the key and nothing happens , no dash lights , no cran
I turn the key and nothing happens, no dash lights no crank , just the blinking security light , head lights work though
Old Jan 27, 2022 | 11:29 AM
JvG's Avatar
JvG
Is your car a 1999 model?
Does the radio work?
How about heater blower and wipers?
I'm asking all this for a reason.
Old Jan 29, 2022 | 12:12 PM
Jcg's Avatar
Jcg
Maxima
It's a 98 maxima
Old Jan 29, 2022 | 12:22 PM
Jcg's Avatar
Jcg
I was trying to tighten up the screws holding the ignition wires down opposite of the cylinder , I grounded out the screwdriver the engine then started to crank over like it was being "hotwired" I stoped , tried turning the key and nothing no dash lights to click nothing
Old Jan 29, 2022 | 08:51 PM
JvG's Avatar
JvG
Did the car stop running by its self all of a sudden?
Did you attempt a repair procedure of some kind, after which the car would not run?
We need more information.
A photo of which wires you are talking about would help.
We diagnose well given enough descriptive information.
It's ok to have Reverse Midas Touch. Lol.
Old Jan 30, 2022 | 03:58 AM
Jcg's Avatar
Jcg
No I had just got the car running again replacing crank pos sensor,any way, I had always had a problem with the cylinder, I would turn the ignition to start position and nothing, it'd sometimes take 5- 10 tries till it would "catch" and turn over , well this time it didn't want to start at all , witch is why I was tightening those little screws holding the wires , on the other side of the cylinder I'll get pics soon
Old Jan 30, 2022 | 02:55 PM
JvG's Avatar
JvG
Ok.
So you are talking about the electrical portion of the ignition lock?
Those are known to fail. They act like you describe when they do.
They cost about 30 dollars.
Instructions are on the forum, or on youtube.
It's not difficult. Can be done in half an hour.
Old Dec 30, 2024 | 07:07 PM
Jaustin73's Avatar
Help
My son and I were installing a backup camera. We were using a multimeter to verify which wire was the reverse light, when my son noticed the instrument panel had shut off and gone black. The car was running. He turned the car off and now it won’t restart. It’s a 2006 Altima. We have checked every fuse we can think of, could it be the immobilization feature? Or did the transponder key get screwed up even though it was in the ignition when this happened? Everything works in the car except the dash lights and it cranks but won’t turn over. We have checked battery and it’s fine, also we don’t hear the fuel pump kick on but I read that the immobilizer disables it.
any help is greatly appreciated!
Old Jan 2, 2025 | 07:32 AM
95maxrider's Avatar
Lightly modded
You do realize you're on a Maxima forum, and not an Altima forum, right? It does sound like the immobilizer is acting up, but I can't imagine how given you were just using a multimeter on some tail light wires.
Old Jan 2, 2025 | 09:41 AM
Jaustin73's Avatar
Yes, I do realize the forum. But Nissan may have similar issues throughout makes, worth a shot.
bigjo11411
Dec 14, 2012 09:14 PM
slimer
Sep 2, 2005 08:06 PM
Pearl90gxe
Jul 22, 2004 02:25 PM
Steve Marsh
Dec 28, 2001 02:18 AM
