Maxspeed springs....any failures for anyone?
mine are A-OK.
for before and after pics of the install, go here: http://www.geocities.com/the_real_G_...uspension.html
hope this helps!
FLO_BOY
(aka TheRealG)
hope this helps!
FLO_BOY
(aka TheRealG)
Nice Pics, is it a 1.5" drop? hows the ride with AGX and maxspeed?
Some 5th gens are running maxspeed and like it (read a few posts on it a while back)
I think hes trying to find out if anyone had problems at all with them cause he is interested in purchasing some Maxspeed springs.
Originally Posted by 96white
did yours fail?
Originally Posted by maxspeed96CT
rough ride and not much of a drop.
i had them paired up with gr-2's , its a inexpensive setup if you just want to loose the 4x4 look.
I thoughts so, is the pic in your sig with the maxspeed springs? doenst look low at all.
BUT, I can't compare "harsh-ness" as I've only dropped with MaxSpeeds.
With any drop, the ride will suffer...I suggest finding someone local and deciding for yourself about the ride stiffness.
good luck!
FLO_BOY
(aka TheRealG)
the ride is alright. not too stiff, not soft. drop isnt much. im running on stock se shocks and i have no problems ...yet. mine squeak like no other on bad roads. its pretty annoying on freeways. i dont like mine as you can see. i suggest getting something better like progress and pair it up with good aftermarket shocks.
I was there for his install, he has maxspeeds with gr-2's.
I was there for his install, he has maxspeeds with gr-2's.you quoted me, and you weren't at my install -- I'm in Canada
anyhow, I suggest you try and arrange a ride in a lowered MAX, because, the ride will suffer from stock.
FLO_BOY
Sorry, I meant it to be for when Mdezzy said " I think hes trying to find out if anyone had problems at all with them cause he is interested in purchasing some Maxspeed springs."
that i was at JLiusifer's install, and that he already had the springs.
The Wizard
24
Oct 1, 2015 08:47 PM
