Autoo tranny problem
Fluid level is fine, and its a nice rosey pink. But It's not shifting right, and when its cold in the mornings, unless you let it warm up in park for about 15 minutes it will stall the car right away. For the next 30 minutes or so, when it idles, at a light it idles very roughly, almost like a 5-spedds clutch thats not disengaging all the way. Any thoughts as to what could be causing it?
im not sure how much a regular torque converter would cost... but i know a level 10 torque converter is around 400 dollars, this is what i am getting. its an upgrade to a regular torque converter, or so i have been told
Be aware that the 4th gen used plastic valve bodies in teh trans to hydraulicly control shifts. These are prone to failure.
On wife's 96, it totaled up to worn clutches on 1st, second, worn drum on first, and a new set of valve bodies (the good metal replacement ones).
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
