Sporadic starting issue...coilpack? starter?
My car has an odd problem. Very rarely, it hesitates to turn over when I crank it. I have noticed that whenever it does happen, it is usually when the car was parked not much longer after reaching operating temperature, and then restarted shortly after (while it was still warm). You know, like going from home straight to a nearby gas station/movie store, parking it for 5 min. or less and then restarting. I then pump the throttle just a little while cranking and it starts right up. No problems while driving, btw.
And this has never happened on a cold engine; not even once.
An odd little issue, wouldn't you say? Could it be a coilpack beginning to act up or is it something else?
Originally Posted by usmanasif
... it hesitates to turn over when I crank it. ...
Trying to:
1. Cranking speed is less than normal, or sporadic
2. Engine does not fire [no cranking problem]
Few of possible causes:
1. Starter, solenoid - as mentioned, and/or batt cable connections
2. O2 sensor, ign key switch worn, ign related contacts under hood.
Yes, it cranks just fine, but cylinders don't come to life. Starter seems like a good starting point. I wouldn't blame the ignition system as if that were the case, either it wouldn't have cranked or would have had low starting power. Battery connections are good as well. I am going to launch an all-out assault on it one weekend and try to figure out what's going on.
I really appreciate the input, guys. Thanks!
Then: 2. O2 sensor, ign key switch worn, ign related contacts under hood.
- O2. dunno.
- ECU has to get the ign on signal from ign key. Not heat related.
- ign related contacts under hood: warming increases resistance
- If pedal movement helps, TPS is dirty.
Btw. Do not flame on me. Somebody might get angry and burn u I/O. You know as much of my ip etc as I am willing freely to inform. Even superman was paralyzed after fellinh off a bench...
- O2. dunno.
mikeg75
Nov 30, 2015 05:12 PM
QueensMAX
Sep 15, 2015 04:14 AM
