Spark Plug Boot stuck on plug! Need Help!
I was changing my sparks plugs last night and everything was going smooth till I got to the last one. When I pulled the coil pack out the boot did not come with it! The boot is still on the plug. Has any one encoutered this? Any ideas how to get it out?
That's what he said, no need to repeat it. It's not broken, the adhesive just finally let go. This happened to my friend twice. First time I used so rubber cement, let it set and pulled it out. Second time, well, he still has the old plug in there. Did you bother to try super glue or some other strong adhesive or did you just run to the comp as soon as it happened?
Use crazy glue, just put a few drops on the tip of the stem, put it back onto the stuck boot down in the spark plug hole.
Go have a beer
When you come back the boot will come up when you pull the coil pack.
Go have a beer
Bah, you patient people.
I've bought two junkyard coil packs for just the stems and boot. I was too impatient and ended up ripping the damn boot out (either using needle nose pliers, failing with the super glue trick, or a jig).
I superglue the stems to the boot now.
Holy hell, a real use for crazy glue? I've used that stuff on various things in the past and it's been consistently garbage. I still am annoyed to think of the pic of the guy hanging wit the hardhat and one drop of that junk. It's about as sticky as shampoo, and holds no better either.
Well, I'm done ranting. Apparently in this case it does work.
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
Need help
23
Oct 2, 2015 08:56 AM
