iacv adjustment/cleaning
Old Feb 21, 2005 | 06:33 PM
blacks92seAuto
Does anyone have a write up or info about the iacv and how to clean it or adjust it? and what would the beneifit be? smoother idling engine?
Old Feb 21, 2005 | 07:35 PM
Harvs94max's Avatar
ill help u out once i know vg or ve
Old Feb 21, 2005 | 08:34 PM
MrGone's Avatar
VE:
There are 4 bolts holding it on, unbolt them, disconnect the idle air tube and coolant lines. Take it off, clean it out (Q-tips are handy). Might notice a smoother idle. I would just clean it for the sake of keeping the engine in tip top shape. There is a screw on it that will adjust your idle (side facing the radiator IIRC).
I would buy gaskets for it before you take it apart. Those gaskets always tend to be brittle and break.
Old Feb 21, 2005 | 11:58 PM
Wiking's Avatar
If you have VG30E, check out:
http://www.cardomain.com/memberpage/748507/1
schmellyfart
Sep 25, 2015 04:47 PM
junito1
Sep 23, 2015 12:14 PM
bumpypickle
Sep 20, 2015 08:22 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
nbstriker10
Sep 4, 2015 04:26 PM
