4th gen: USIM vs. 00vi
SO I went to the track this weekend, got some nice results
Sad this is, this is WITHOUT the RPM switch. I have it wires to a manual switch. I flip it on when I hit 4500, turn it off as I shift to 2nd, turn back on at 4500 and 1/8th mile is over. I only did one run like that. All the other runs, I only turned on VI in 2nd gear and I got a best time of 10.001. So with a working RPM switch and better 60's, I can expect mid 9's or less.
Best with USIM:
60': 2.3
1/8th: 10.1 @ 72mph
Best with 00vi:
60': 2.3
1/8th: 9.8@ 74mph
Best with USIM:
60': 2.3
1/8th: 10.1 @ 72mph
Best with 00vi:
60': 2.3
1/8th: 9.8@ 74mph
Originally Posted by kevlo911
Nope.... I dout MEVI adds to 1/8 mile w/o ECU
Originally Posted by deezo
...but when you add the ECU to the MEVI, it changes things. My car pulls hard as hell with the ECU all the way to redline. Jeez, I love my car all over again.
What about 00vi with ECU
Originally Posted by Nismo3112
I would think there would be even more of a gain in the 1/4, knowing you spend a little more time in the upper rpm's?
this is a good showcase ( as long as temps, and track were in the same area) .. the OOVI really seems to be the new king of the 4th gen intake manifolds. it appears we have the 00vi here in NZ, i think. the 4th gen looking cefiro body style have 30 more hp over the maxima (190 vs 220 hp )which seems to make me think it must be some sort of vq30de-k . so maybe i can look into this one day as well. im set to go on the extrude honed project soon, but looks like it could be a bad move, not sure.
The only thing that makes to MEVI 2nd to the 00VI IMO is the cost. Both have pros and cons. But, the cons ahve to be something you are willing to work with. The MEVI with modified A/F ratio and timing makes beautiful power all the way up to redline and beyond. Acceleration is beastly, I mean simply incredible. Without the A/F and timing changes, engine power just plain sucks.
With the 00VI, you don't have to do much of anything to keep the original power in the low and midrange, plus adding power up top except for dealing with the modifications or getting it onto your VQ. It's basically a 4th Gen manifold with a VI added to it.
I had a chance to go 00VI but decided that I should really work with what I have. I really didn't want to do all of the extra work needed to get it working, plus it would have cost me more money than the average person that never had a VI from the start. I waited a looooooong time for my VI (which actually came straight from Japan on a ship) and feel I need to do some track justice with it.
deezo that sounds right, get some track time, enjoy it. is extrude honing the usim a waste of time when you have the 00vi now ? EH would still be plug and play verus the other setups right ?
Ill tell you that 00 vi has to be one of the best IM's designs ive ever seen. And its not even true dual runners.
And that is why it will be the intake manifold on my 03 maxima engine.
Originally Posted by the chariot
krismax, if you replace the USIM with the 00vi, does this mean you need to grab the extended rev limiter upgrade, im way behind on this IM and whats going on with it.
He's probably doing it anyway but I'd like to see him build up the 3.5 a bit so he can run the high rpms.
I will definitely get to a track this year.
thats rigth deezo, but im wondering is you do the 00vi is it supposed to be used with an ecu with extended rev limiter to something like 7200 rpms like the mevi guys use.
James92SE
142
Jan 2, 2024 09:23 AM
t6378tp
Sep 29, 2018 04:27 PM
CAN-Toronto 97 SE BLACK w/ BLACK. PART OUT.
worldwiderecognized
Sep 24, 2015 06:56 PM
