Just a few things on a high milage 5.5
I recently rolled over 100k on my '03 (ya, I drive a lot, now shut it about that!) and thought I'd run down a few things that some of you can expect and how to fix them:
First problem I had was the rattle from the interior fan. Bearings died in it. There is no fix and it'll only keep getting worse till it fries itself. I bought a used one at a junkyard for 60 bucks and installed it in fifteen minutes. Fixed.
Secondly: Valve rattle. At 2,500 to 3k rpms and no load, the 3.5 liters can get a rattle. I tried seafoam just because it was cheap and I thought that maybe by cleaning the fuel / air system it would go away. Well, it helped, but didn't stop it. I dealt with it for 30k miles and then changed the plugs. I think that the increased gap in the sparkplugs due to wear caused for a slightly retarded timing by not making the fuel ignite quite as soon as it should have. Since I changed the plugs, the engine is smooth again.
Third: my transmission had started slipping at 40k. At 103k I had to buy a new one. I think it was kind of a freakish accident, but it died. Make sure to follow the intervals in the manual for transmission service. I let mine go for 50k on my second interval and vola! No tranny at 103k.
Fourth: my climate control system seems a little fcuked up now. The fan now has three speeds: off, low and a little faster. The switch also seems to act funny for the fan. Also, my A/C switch works when it wants to now. I haven't had a chance to work on it, but sometime soon I'll be tearing it open and seeing if I can find the problem. I'll get back to you on that.
I'll try to keep this thread updated as I rack up the milage. My job requires that I drive 50k a year, so if anyone is prone to mishaps, it's me.
Originally Posted by mjg
Hmm
I'm only at 27k miles. I know at 30k there is a big service to be done, anyone want to explain to me exactly what that is?
Tranny oil change
Tire rotation
Air filter
In cabin filter
Check all kinds of crap
Lube doors, sunroof, etc.
Coolant flush
My dealer did for $149
Originally Posted by schernov
I also had 2 O2s replaced plus ECU reprogrammed and a Right rear ABS sensor (goodwilled)
did you notice any difference in the car after o2 sensor was replace and the ECU reprogrammed, ? dealer quoted me $330 for one 02 sensor and ECU repgromming. I was told that hte new ECU program helps with other thinks like hard shifts etc.
I have a manual tranny, so I did not really notice anything. Only one o2 was bad, but according to TSB they had to replace 2. They were $115 a piece plu labor was like $400. I could not take it to my mechanic cuz of the stupid ECU reprogram (he does not have consult)
Oil change
Tranny oil change
Tire rotation
Air filter
In cabin filter
Coolant flush
Tranny oil change
Tire rotation
Air filter
In cabin filter
Coolant flush
Originally Posted by Y2KSilvahSE
No coil problems? Brake judder/warp? Wheel bearing issues? MAF issues?
Actually, it started off making noise only when it was cold and on high. Over time, it started to make noise at all speeds when it was cold, then it really began to crap out and just made noise all the time at all speeds.
Originally Posted by SEmy2K2go
You mention there is not a fix for that issue. Is it that it is not warrantied or is there another reason?
Originally Posted by 03blk6mt
Exactly what mine was doing! Gone at 32K. How cheap are these parts that we can't even get a couple of years outta them??!! Wonder if the Infiniti guys have these same type of irritating issues?
I'm sure it would be covered under the warranty, however, when it died, I was way out of my warranty. The reason for no fix is because the bearings are sleeve bearings, no ball bearings, so when it died, the cash you would spend to fix it would be better spent on going to a junkyard and buying a used one.
Try resetting the throttle position sensor. There was a thread about it last week. I haven't done it yet, but sounded like it might work.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Mar 12, 2020 12:06 AM
Good post. And the bearings on the blower motor can go a lot sooner than 100k
I may have to change mine soon and I'm at 47k.
