Best rear sway bar???
Anyone want to give props for the best rear sway bar? Looking at getting one, and want to be sure its the only one ill ever buy.
While were at it, Is Cattman's FSTB the best one yet?
Thanks!
Thanks!
Cattman, Addco, and Progress are all the same bar, with different names basically.
The stillen bar is easier to install (if that's possible) but does the same thing.
All are just as good as the others....
as to FSTB, all are the same. The cattman LOOKS nice, but does exactly the same thing as a $20 ebay FSTB....
yes i know josh you're probably sick of me and my questions by now...
edit: this question would probably make more sense if i included the link to what i was refering to...
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7958541321
Originally Posted by Larrio
"best" is too subjective, especially with car parts.
I have the stillen one and its the only one that is adjustable. How often you'll actually need adjustment is unknown
that said, I've never felt a need to adjust it!
XGaSpAcHo, that's the same bar I have, the Otto one....fits well, good quality. Yes, you should torque the bolts to factory spec (I don't remember what spec is, but check a Haynes manual or FSM...)
i've adjusted it a few times while a full length track events. But otherwise it just stays in the neutral 3 and 5 hole position
maxima-ness - the website is being developed and isn't working. Try temaxima@hotmail.com for inquiries. And the *** is a long story, better left unsaid
Originally Posted by XGaSpAcHo
this one look ok? for $35 i'd get one. do i have to tighten the screws with a certain force or just as tight as i can get them?
Here's a nice pic for you.
Originally Posted by CCS2k1Max
Do NOT overtighten the nuts as the bolts are real easy to brake off. I'm on the road this week so I don't have access to the FSM, but from memory, the torque is somewhere around 35 ft-lb.
Adding a FSTB isn't rocket science. You just need the right tools. Buy a tq. wrench. You can pick a decent one on ebay for about half of Sears' prices and you'll keep it for life.
Nope. XGaSpAcHo is talking about FSTBs.
i just ordered the otto one off ebay only to find out that customenterprise.com has their red and blue colored FSTBs on sale for $39. should i try to cancel my order or are they all the same?
Will a sway bar alone make a difference in a gle that is driven normally(not racing or doing crazy stuff?) Is it a breeze to install. Where are the instructions to it? In the "How to's" both links are dead.
The rear sway bar is also an easy install, but it will take longer, and you will need a good jack and some jack stands to hold the rear of the car up while you're working under it. I'm not sure about the Maxima install, but on my Sentra, the RSB required me to use a small spacer to relocate my e-brake cable by about half an inch. On Sentras with ABS, there is one other line that needs to be moved, but it's fairly easy. Since our Maximas all have ABS, I assume it would be the same for us.
A rear sway bar alone isn't going to make your car into a sports car, but it will do more than a front strut tower brace or rear strut tower brace alone, and it will make your ride feel more solid around curves. You'll feel like your car is leaning less, and you'll find yourself slowing down less for curves. I think it's a worthwhile mod, and you'll like the new feel of your ride if you do, as you say, "drive normally."
If you do plan to start "racing or doing crazy stuff," you'll need to combine the rear sway bar with better tires, stiffer springs and dampers, and other mods like a lower tie bar, subframe connectors, and front and rear strut tower braces (even though the strut tower braces are probably the least dramatic suspension mod, they're cheap, and people like to have them to "complete the package").
lowpost99
Oct 26, 2025 06:53 PM
bbsitum
Sep 11, 2015 04:55 PM
flu2000
Sep 8, 2015 02:23 PM
