Transmission whine. Help.
Car: 2000 GXE 5pd
Symptom 1: The tranny whines when the car is parked and the gear in neutral. The whining stops when I press in the clutch.
Symptom 2: It whines in 1st gear.
What could be the cause of this? I don't remember when it started doing this.. I did change the tranny fluid with synthetic couple years ago. Can low/too much tranny fluid be the cause of this? I'm pretty sure I put in the proper amount.. If the tranny oil leaks, where do I need to look?
HELP!
HELP!
Possibly the clutch throw-out bearing is bad. Do you spend a lot of time on the clutch... living in NOVA I know you spend a lot of time in traffic. Stop & go traffic is hard on a clutch. Take it to the dealer for a confirm.
Originally Posted by hokiemax
geeeez....
so how much is it to replace the throwout bearing? Anything that I should watch out for while getting this performed ?
Pied
Sep 26, 2015 03:29 PM
