Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Oil thickness advice for -10F all the way to 102F
Old Mar 7, 2005 | 04:40 PM
renatonetmail
Welcome to NJ (-10F all the way to 102F)... *sigh*
Got new car 95'MAx 5spd 88K "unknown" history mileage on it.
Major tune up about to start.
Gunk engine flushing done
Mobil1 Full Synthetic comes out as the clear winner.
My question: 5w-30, 10w-30 ? Both? any other grade? why?
Thanks in advance for the input.
Old Mar 7, 2005 | 04:43 PM
XpLiCiT's Avatar
What I was just told is to use 5w30 exclusively until high mileage (80k) then switch to 10w30 if desired
Old Mar 7, 2005 | 04:52 PM
MDeezy's Avatar
10-30 as you get older. I'd say switch to 10w-30.
Old Mar 7, 2005 | 05:38 PM
konak85's Avatar
5w-30=winter/fall ; 10w30=spring/summer
Old Mar 7, 2005 | 05:40 PM
MaximaSE96's Avatar
Maxima Owner
5w30 all year synthetic Blend
Old Mar 7, 2005 | 06:03 PM
adithius's Avatar
5W-30 all the time. The 5 stands for the thinness in the winter. The 30 stands for the thickness at normal operating temp.
So 10w-30 would be the same in normal operating temp, and thicker in the winter.
The manual recommends 5w-30.
Old Mar 7, 2005 | 06:12 PM
renatonetmail
Make sense due to thickness...hmmm...
Old Mar 7, 2005 | 06:14 PM
Ceasars Chariot's Avatar
Old Maxima Legend
RECOMMENDED SAE VISCOSITY NUMBER
- Gasoline Engine Oil
From -20 to +100 F (5w-30) Preferred
From 0 to +100 F (10w-30)
SAE-5W-30 viscosity oil is preferred for all ambient temperatures. SAE 10W-30 viscosity oil may be used if the ambient temperature is above 0 F (-18 C)
Information obtained from page 9-6 of 1997 Nissan Owner's Manual, and for your safety, read carfeully and keep in your vehicle at all times.
Old Mar 7, 2005 | 06:22 PM
Jatan's Avatar
How many oil changes are you planning on doing in a year?
Old Mar 7, 2005 | 06:26 PM
renatonetmail
I don't go by the year, every 5K miles instead since it's full synthetic (whatever time takes me to get to 5K, could be a month sometimes)
Old Mar 7, 2005 | 07:16 PM
Jatan's Avatar
Either just stick with 5w30 all year long or change to 5w30 around Oct/Nov and then to 10w30 around April/May
Mahmuth
Aug 16, 2024 08:23 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
