Is it just me? ROAD NOISE
Old Mar 12, 2005 | 06:56 PM
rule da road's Avatar
I'm sorry i've mentioned this before...
On the road over 15 mph, there is a loud humming noise coming from the firewall. Is it because there's plastic only covering the wheelwell? This noise is LOUD. its not my brand new touring tires, and there are times when i need to turn the radio down.
Does anyone else experience this deafening humming noise?
Old Mar 12, 2005 | 07:16 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
never had that issue on any tires that i been through (potenzas, michelin a/s sports, nitto 555). only humming noise i got was a wheel bearing going bad. did the noise start after the new tires?
Old Mar 12, 2005 | 08:10 PM
pruizgarcia's Avatar
I had a humming from my right firewall when I installed new Sumo HTR+ tires about a year ago. Couldn't find what was causing it; took it back to the the tire shop and they switched out the front tires with another brand for testing and the humming was then completely gone. If the humming started with the new tires, then the tires are probably the culprit. Why, don't know, but I do know how annoying the humming sound can be.
Pedro
Old Mar 12, 2005 | 10:05 PM
remembermorriso's Avatar
I have the worst road noise from the door seal by the rear windows. Its pure highway wind noise. Its the most annoying thing. Its been that way since new.
Old Mar 13, 2005 | 09:27 AM
LA02MAX's Avatar
although this doesnt have anything to do with the original topic...look in the how-to's in the 5th gen forum to see how to fix that...its REALLY easy and cheap.
Old Mar 13, 2005 | 09:29 AM
Nissan SE-R's Avatar
This is common and an easy fix. Read the stickies.
As for the road noise, could be the tires due to different hardness (tread wear rating) or tread pattern. Also make sure that if the tires are directional (built to spin only one direction) they are mounted the correct way on the wheel. Also make sure that your tire pressure is correct.
Old Mar 13, 2005 | 05:02 PM
i had this prob with the stock potenza's too. Got a LITTLE better with touring tires. Its so loud obvious, it must be just me. I think i noticed somethng, when i veer right, its a lot less. I'll do a wheel alignment and see what happens.
Old Mar 13, 2005 | 05:20 PM
irish44j's Avatar
retired moderator
could also be from a bad wheel bearing...a common problem on the maxima.
To reduce road noise I:
- put dynamat (well, Tsunami, a cheaper version) on the floor of the passenger front leg area (under the carpet) and the metal under the back seats
- sprayed rubberized foam undercoating all over the front AND back of the plastic splashguards in the wheelwells. To do the backsides you have to take them off which is a PITA, but with them on you can at least do the front sides (the side closest to the wheel).
these two things greatly reduced road noise.
but, road noise was decreased more when I switched from Falken 512's to Toyo Proxes 4.....car is really quite quiet on the highway now except for wind noise...
Old Mar 18, 2005 | 09:28 AM
And the winner is ........ sloppymax and irish44j!! (usually on point needless to say)
Wheel bearing has gone bad, right side. quoted $200 to repair which will be money well spent. So it basically is just my car and not the maxima design.
Old Mar 18, 2005 | 09:45 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
try switching tires....front and back... I had the same problem with new tires and had to replace the tires.
Old Mar 18, 2005 | 10:37 AM
Puppetmaster's Avatar
those Falkens are loud... I love how they perform, but they are loud....
Old Mar 18, 2005 | 11:59 AM
ZeRo MaX's Avatar
does this happen to everyone?
or is it certain cars or so on?
Old Mar 18, 2005 | 12:18 PM
GBAUER's Avatar
The best fix I found was the **** on my center council that says "volume" in the center of it. Takes care of the wind noise in no time!
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
doctorpullit
Dec 12, 2015 09:39 AM
uttadms31
Sep 30, 2015 05:24 AM
