Anyone get dramatic results with there NEW knock sensor?
hey guys...just getting some feedback on knock sensors...anybody amazed by there new knock sensors?...better feel to the car?...anyone feel lots more power or get much better gas mileage?...POST RESULTS PLEASE!!!..thanks
Def more power since i switched out my bad KS! The old one was cracked and the plastic was all melted. My mpg went from low teens to about 20 mpg big difference, and i didn't even go new , i went with a used one with 90,000 miles on it
Yes I definitely could feel a difference. basically for me, I have an auto, and when i would accelerate under 3000 rpm, the car would normally drag, and the rpms wouldn't increase when you tried to accelerate. Now there is much better response when you hit the gas.
Kinda
Sorta, kinda, maybe...
replaced last week and I *might* have a bit more pull <3K rpm but it could just be my imagination. Only replaced it because the resistance was far too high (see http://forums.maxima.org/showthread....86#post2393786 for test and replacement).
replaced last week and I *might* have a bit more pull <3K rpm but it could just be my imagination. Only replaced it because the resistance was far too high (see http://forums.maxima.org/showthread....86#post2393786 for test and replacement).Anyways thanks for the link, I'm going to check it out!
-illmortal
Originally Posted by NmexMAX
Depending on how long your old one was bad, so you should feel it.
I definitely felt it...more than the y-pipe IMO.
It did, but if you are used to the timing being retarded and just forget you need one, you wont notice it until you replace it, then the car seems like it's brand new. I went 2 years with a dead/dying KS, and the day I cahnged it, felt tremendously different just because I was used to getting owned by stock celica gt's and civic si's and it becamse no big thing, now things are different. You're right it does go into safe mode, but if you're used to it and don't notice it, when you change it, the results will be far more appreciated.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
mkaresh
Mar 12, 2018 06:48 PM
