Change Tranny Oil with Redline Mt-90 but..
Still kinda often I can't get it to 1st gear. When it shift smooth i feel in my hand two strokes...kinda like "engage" and "lock" (<--- i came out with those two words just to illustrate) ...well... when it doesnt want to shift it stays on the first stroke...like i never finish the throw to "lock".
Solution 1: Shift into second or third and back into 1st
Solution 2: Clutch press and depress again.
Any input on this?
Any input on this?
Our tranny's 1st gears are hard to get into even if your car is rolling pretty slow (say 5mph), i cant get into it at that speed, I have to come to either a full stop or to ALMOST full stop and revmatch it to go in 1st gear. I may be wrong but I think 1st gear (similarly to reverse gear) has a lock-out. I guess to prevent any damage to the drivetrain in case u try to go to 3rd too fast and end up goin back into 1st (reverse usually wont let you shift into it unless you're full stopped, I tried doin it at a slow roll (2-3mph) and it'll grind if I do it.
EDIT= your 1st solution seems to work for me. Sometimes even at full stop if wont go into 1st gear (usually when it still cold, doesn't happen to me onces its all warmed up), so yea I go into 2nd and up to 1st and it goes in no problem like that
that's is just crazy... how about the shifting linkage...maybe is that? I was reading in the troubleshooting section on Haynes about the problem going into specifically 1st gear and they point at the linkage. hmmmm?? *confused*. I've been never a fan of "something to get used to" idea. how come it never happens when cold.
Our manual trannies shifting sucks. Sometimes at a light, it's difficult to engage 1st without double clutching. This was noted on some "new car" reviews.
BTW, you really aren't supposed to shift (back) into 1st unless the car is stopped. There is no synchro, iirc. Second gear is just fine as long as you don't WOT it.
Chunger is right: It seems a common complaint that 1st gear is often hard to go in w/o the 2-1 "trick" or cycling the clutch. 1st gear has no syncros, and it's not advised to go into 1st while moving.
I use Redline MT90 as well and at first, I thought something was wrong with my tranny. Found out later that this is pretty common. The way I go around this is:
1) Pull the shifter towards you while shifting to 1st. That usually works everytime
2) As you hold the shifter towards first, SLOWLY let go of the clutch until the shifter finally goes into 1st. I rarely have to do this.
3) Sometimes at a light I'll forget about step one and since people are so damn eager to go as soon as the light turns green, step 2 is no good. So, I double clutch it then shift to 1st.
This is the only thing I don't like about our 5-speed. I wonder if the 5th and 6th gens have this issue?
Its not necessarily bad. Its a safety mechanism on the tranny. And it really depends on how you shift. The 1st gear lockout mechanism prevents anyone from shifting to 1st while going above a certain speed. My 89 Toyota Celica didn't have this feature and I'll admit, I have abused that tranny and destroyed it at 140k miles. At first the synchros went, then I lost 1st gear, then 2nd gear, and its all over.
It has happened to me many times when I'm sitting at a red light, and when it turns green, I can't put the shifter in 1st. That's when method #1 works. One thing I just remembered, the carpet in my maxima is one of those generic ones. And sometimes, the carpet on the driverside had slid up so far that it got under the pedals. Then you try to depress the clutch and wonder why the shifter isn't going in easily. That's because the clutch pedal isn't down all the way because the edge of the carpet got under the pedal.
When I switched to Redline, shifting was really smooth. Didn't even get the notchy feel. But after a little while, it came back. Last year when the cv boots had split, I took it to a buddy's shop. The tranny did loose some fluid while pulling the axles out for the boot job. He probably added a half a quart of regular TF because I forgot to get some Redline. Its been a year since and I have always wondered if it was wrong to mix a little bit of regular TF with the Redline already in the tranny.
Originally Posted by 1FSTMAX
same with redline oil, just a little smoother...
That should worry you a bit since there might not be a lockout mechanism for your 1st gear....who knows. I'm not saying there isn't either but I know mine does because I definitely can't shift to 1st unless im going below 5mph.
...i could get into 1st gear at low speed without double clutching, or jamming into gear..
97_GXE
20
Sep 17, 2015 08:12 PM
ag90fox
Sep 9, 2015 12:22 PM
pktaske
Sep 4, 2015 08:40 AM
sdotcarter
Sep 2, 2015 09:53 PM
Are you guys running race clutches?
