Car Won't Start - Crank POS Sensor Fault - HELP I'M STUCK
Last, as I was GOING to leave work, but my 95 SE wouldn't start. It sputtered hard but never ran. Then is wouldn't turn over at all.
Even tried to jump start it, but nothing.
At the same time, I got a 0407 ECU code (Crank Position Sensor - REF). So I pulled the wiring harness and then sensor. I check the resistance of the sensor vs. Haynes Manual and found that it was in spec (527 ohms @ 68 deg).
After doing some research in the forums, it would appear that it could be the starter b/c it's not spinning the crank enough for the sensor to find TDC of a cylinder.
Could it also be the battery? It's only 18 months old.
Anyone else run into this sort of thing???
So...maybe starter....maybe battery...maybe ????
HELP!!! I have no vehicle that runs!!!
The crank sensor does not have a specific resistance per temperature. Your not looking at the right sensor. Crank position POS is located under the car on the transmission bell housing. It looks at the flywheel. It's tested with voltage, (5 volts) not resistance.
Ref. Haynes manual, section 6-12.
The one you mention above is the POS sensor. My code was for the REF sensor.
You are correct in that the POS sensor is a voltage test, but the REF sensor is a resistance test...per Haynes...same page you mention. Check out the middle column on that page.
Sorry I don't have any info to help you, but I had the same code..car would crank but not start.. I ended up buying the new sensor and then my light went away. Try cleaning the sensor. If you determine that you need a new sensor, let me know. I still have mine, brand new, in box, never used, with original receipt.
check both sensors, make sure harnesses are plugged in tight and clean the sensors. Happened to me once the car shifted hard and it knocked the wiring connector loose. Car shut iff right in the middle of the road. Plugged it in tight and it was A OK. Those sensore are just magnets so they shouldnt go bad. Def try cleaning them both.
Originally Posted by 98MaxBoi
My car was also has the same problem the crank pulley has reached the REF Sensor which means u have to repleace this pulley with the REF Sensor . hey, ur car will start if u tried so hard
I got it started tonight by pulling it behind my wife's suburban and dropping the clutch into 2nd gear. Started right up!
Ran fine all the way home.
I think it's the starter now. Once I got it home, I couldn't get it to start. Just dead.
Well at least now I can work on it!!!
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
BobMax
Aug 15, 2015 12:35 PM
