Auto Trans Valve body Removal?
Old Mar 16, 2005 | 01:09 PM
Junxster (NoVA)'s Avatar
Has anyone dropped the valve body on the auto tranny? I've been told by a nissan tech that the reason for my hard shifts is because some solenoids on top of said valve body need to be replaced.
Old Mar 16, 2005 | 02:07 PM
soundquest's Avatar
I am getting an ECU code that is telling me my line pressure valve solenoids are acting up as well. I am going to see if a power flush will solve the problem. To replace the parts (there are 4 solenoids in total that all come together in a pack) it costs $79.00 at my nissan delaership. I don't know what they charge for labor because i will be doing it myself.
Old Mar 16, 2005 | 02:20 PM
vsamoylov
it is preety simple.
drop the pan, and after you do that, you can see the valve body. i cant remember how many bolts hold it in place but i know there is diffinatly a couple. also you need to disconect the connector that plugs into the valve body. plus it is a messy job casue of all the oil.
Old Mar 16, 2005 | 03:05 PM
soundquest's Avatar
Have you actually replaced your line valve solenoid pack before? How much did you buy the part for if so?
Old Mar 16, 2005 | 03:15 PM
vsamoylov
no i havent but i taken out and put back in the valve body.
Old Mar 18, 2005 | 08:31 AM
Bender-san's Avatar
The harsh shift is due to a boost in your line pressure becuase the solenoid that controls the line pressure is allowing ALL of it to go through. Do me a favor if you could: Ohm the wires to that solenoid when you pull it out and check for open resistance. If that sucker stays open, then we auto-tranny owners may not need expensive valve body work anymore to improve shifting.
tgreen
Oct 18, 2015 06:18 PM
Max139617
Sep 20, 2015 07:09 PM
Maxboy23
Sep 9, 2015 10:37 AM
03VQMAX
Sep 5, 2015 03:47 PM
Maxboy23
Sep 4, 2015 06:04 PM
