What type of ATF does everyone use?
Old Mar 18, 2005 | 07:36 AM
dki378's Avatar
I'm sorry if I've become a nuisance already but I can't seem to find anything on the forum regarding this. I've tried using the search tool but for whatever reason it will not work for me. I'm sure someone has brought this up in past so this may be seem repetitive to some but what type of ATF (automatic transmission fluid) does everyone use? Synthetic or standard? Brand? etc.
Old Mar 18, 2005 | 07:53 AM
adithius's Avatar
Nissan-D. I think it's worth it for the tranny flush that the stealership does for $139. (One of the few things I take it to the stealership for) You can use Synthetic if you want, Mobil 1 or Amsoil.
Old Mar 18, 2005 | 10:38 AM
blkmaxx97's Avatar
Amsoil!!!
Old Mar 18, 2005 | 10:44 AM
Bobo's Avatar
It helps to know what year your car is, what the mileage is, when you bought it and how many miles were on it when you bought it.
Old Mar 18, 2005 | 03:08 PM
dki378's Avatar
Sorry for not clarifying...
I just recently bought a 99 Maxima SE Limited with 75K on it. I'm trying to get her fluids all changed out but I'm still trying to decide if I should do some of the work myself or just take her to the dealership. With this information at hand, what would you suggest as far as ATF? Thanks for your help. I apprciate it!
Old Mar 18, 2005 | 03:44 PM
big_al's Avatar
Amsoil......
Old Mar 18, 2005 | 03:59 PM
95bkackmax18s's Avatar
is it hard to do this yourself for the first time? i mean if you can do a oil change, can you do this?
Old Mar 18, 2005 | 07:12 PM
97MaximaSE's Avatar
i use gm or nissan fluid since i get both for free.......a drain and refill is easier to do than an oil change....pull the plug, drain, put in 4 quarts, go through the gears and your done. a flush is a different story
Old Mar 18, 2005 | 07:18 PM
Max Atlanta's Avatar
Go with Amsoil. It should run about $7.50 a quart.
Old Apr 17, 2005 | 06:01 PM
soontobe's Avatar
I use amsoil.
Old Apr 17, 2005 | 06:05 PM
A Flood99's Avatar
if you're automatic, use the Nissan Matic-D
Old Apr 17, 2005 | 07:33 PM
anarchy57's Avatar
is Amsoil hard to find for you guys too? Around here I havent been able to find any..
Old Apr 17, 2005 | 07:48 PM
zazon's Avatar
PM talkinghorse, hes really helpful and can get you dealer cost and cheap shipping on anything
I run mobile 1 synthetic cause i caught a slickdeal at autozone when they had it priced wrong: 1.29 a quart x 14 quarts = cheap flush
Old Apr 17, 2005 | 08:41 PM
Dan's Avatar
Dan
No Longer Owns a Maxima
Get amsoil from www.myoilshop.com. It's good to change all the fluids if you just got the car, unless you have a record that they were changed recently. Coolant, oil and power steering you can do yourself. Look at motorvate for the procedure. (Link in FAQ). Brake, tranny and clutch (if manual) leave to the pros.
Anyway, welcome to the org. Post some pics of your new car when you get a chance.
Old Apr 17, 2005 | 08:43 PM
zazon's Avatar
if you can do a coolant flush yourself you can definately do an ATF flush yourself
Old Apr 17, 2005 | 08:46 PM
Dan's Avatar
Dan
With coolant you don't even have to jack up the car or anything. Tranny you do...
Anyway, here are some links:
P/s Fluid: http://www.motorvate.ca/mvp.php/702
Coolant: http://www.motorvate.ca/mvp.php/502
Oil: http://www.motorvate.ca/mvp.php/511
Old Apr 17, 2005 | 08:47 PM
zazon's Avatar
i didnt jack mine up to do the ATF flush, did you?
Old Apr 17, 2005 | 08:49 PM
Dan's Avatar
Dan
I have a manual...They put it up on a lift to change the tranny fluid.
Old Apr 17, 2005 | 08:51 PM
zazon's Avatar
oh, i have an auto, theres a great writeup for doing the ATF flush in the Fluids & Lubes subforum on this board
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
NismoMaxi02
Oct 4, 2015 09:09 PM
MichMaxFan
Sep 30, 2015 09:18 AM
TheMafia
Sep 4, 2015 08:26 AM
