stock bose amp bypass writeup please
can someone provide a step by step write up on how to bypass the front and rear bose speaker amps? I need to install aftermarket speakers but i dont know how to bypass the amps. i have a 91 se
It may be on Craig Brace's home page but all you have to do is cut the wires going into the amp. There are 4 wires, 2 are thicker than the others (red and black) these are the power wires and you can keep them hooked up, no need to cut them. The other 2 wires are speaker wires. One is pos and one neg. I am unsure of which is which but you can hook up a volt meter to find out. That's how I did it. The back will take about 5 minutes to do, just get into the trunk. For the front ones you have to take off the door panel and take out the self contained speaker/amp setup and work from there. Check out Craig's page it's very helpful.
Originally Posted by Dj Paul
or you can buy an adapter for 15 dollars and bypass them
