VE 5spd motor into VE auto car. misses under load
Just had my good motor taken out of my crashed SE5spd and put into a 92 SE auto. Engine idles fine and revs OK at stop, but sputters, misses, hesitates and damn near backfires under load on the road. Still has maybe 3/4 power, but feels rough when it's pushed.
I was told the manifolds were different, but I thought I got around that problem and got the booster to work when reved.
Any ideas and help would be appreciated. The friend who did the work is at a loss for ideas.
Could someone who is able do a search for this kind of swap on the .Org?
TIA!!!!
TIA!!!!
Unfortunatly after an engine swap, there are too many possibilities. Start with easy electrical stuff, injector resistance (there could be a pinched wire), ignition coil resistance, do a compression test (burnt valve maybe). MAFS, TPS, Temp sensor.
Originally Posted by rzirker
what is TPS? and could the temp sensor have that much affect? Both fans have been running. I expected to change it out later.
You might want to talk with Jeff. He has done a few VE swaps, but I think all were AT to MT swaps. The JDM VE engine he swapped for me was an AT. I am pretty sure everything on the engine itself is the same on MTs and ATs except the power valve for the variable intake.
If it idles OK and revs fine at a stop, it would seem that everything on the engine side is working fine. Maybe you messed up something with the tranny? Otherwise, I would guess it was a vacuum problem or something electrical, like the previous posts suggest.
Bad gas?
clogged injector?
how old is the gas that's been in the tank?
I had some very similar things happen to both of my cars in the last couple months.. then I realized I filled up at the same cheapo gas station near the house on both cars..
ran that gas out, dumped some injector cleaner in it and refilled with Mobil 1 93 octane.
the problem went away after about 50 miles.
clogged injector?
MaximaDrvr
Aug 19, 2015 08:20 PM
