timing belt
Old Mar 22, 2005 | 06:40 PM
ltgerms's Avatar
timing belt
What is the recommended mileage to change a timing belt for a 2000 Maxima GLE?
Old Mar 22, 2005 | 06:41 PM
THT's Avatar
THT
Throbbing member
You don't have a timing belt...you have a timing chain.
~THT
Old Mar 22, 2005 | 07:37 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Chain... 100K +...
Old Mar 22, 2005 | 08:28 PM
maximillus's Avatar
what about for the 02 maxima?
Old Mar 22, 2005 | 08:40 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
same ****, its good for the life of the engine but good idea to change it around 250K miles when doing the water pump which will probably leak around 180K miles anyways.
Old Mar 22, 2005 | 08:43 PM
Bobo's Avatar
I thought all you had to worry about is the tensioners.
Old Mar 22, 2005 | 08:56 PM
yeah but chains are cheap and not too hard to swap. I would just swap them out while doing tensioners- or in my case cams. I got 104K miles on mine and its getting louder in the timing chain area.
Old Mar 24, 2005 | 05:49 AM
ltgerms's Avatar
Thanks! My friend's timing belt blew on his Jetta so he was making sure that wouldn't happen to mine...got 86K on the '00 Maxima now!
Old Mar 24, 2005 | 08:34 AM
† ErV †
VWs (his is a 1.8t right?) have a flawed timing belt and assembly straight out of the factory. you don't have to change the chain on a maxima unless it gives you problems.
Old Mar 24, 2005 | 12:44 PM
irish44j's Avatar
retired moderator
change the timing belt whenever you change the blinker fluid....never!
Old Mar 24, 2005 | 04:03 PM
FusionAcid's Avatar
but i just changed my blinker fluid last weekend. hmmpph!
Old Mar 24, 2005 | 04:15 PM
FanaticMadMax's Avatar
Ditto Nissan don't use belts. What the heck is blinker fuild? This is the first i ever heard of
Old Mar 24, 2005 | 06:39 PM
wngan9447's Avatar
Chicken Feet Croo!
Blinker fluid gives your blinker a color.. other wise your bulb would light just white...
Old Mar 24, 2005 | 07:44 PM
mingo's Avatar
i was always under the impression that themz chaings are a PITA to change, don't u have to pull the motor to do it? i was thinking of never changing mine, blow the motor and just put a built one in.. i have 112k on my motor already and i'm about to introduce my motor to a snail
Old Mar 24, 2005 | 07:54 PM
Bensmax00's Avatar
dude--no BELT--timing chain, and u dont have to change it ever--unless it starts making noise or u jump teeth due to some freak accident---Nissan has
done away with the BELT--no more Nissans have beltsand Maxis havent had a belt since like 93 or 94
Hondarydr
Dec 30, 2024 06:15 PM
tsi6001
Oct 3, 2022 10:23 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
Ray229Harris
Sep 16, 2015 08:16 PM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
