ECU- I can't find this thing.
I must be the biggest moron on the face of the plannet. I tore apart the center console, all I could see is the airbag unit (?) w/ the two yellow harnesses. Does someone have pictures on where the ECU is in the SE?Thanks.
stick your head on the floormat facing the center console (pass side) now slide it up (foward) .. behind the radio dash part. you will see a black plastic piece with 2 screws (one with a cap on the screw the other is a screw/clip) remove them and remove the plastic plate... now you will be looking at the ECU.
Originally Posted by Maxima_Mike
I had trouble finding it too. Cheocwa had to point me in the right direction because I kept looking in all the wrong places. Don't feel too bad.
http://www.cardomain.com/memberpage/748507/1
You should get one: Or read this 10x btw it's in the stickies
http://www1.autozone.com/servlet/UiB...3d801f4e65.jsp
Originally Posted by MaxNub91
sry, i don't have one of them manuals, and i don't plan to spend $20 to buy it, does anyone have a write up on how to remove it? thx
1. Take connectors off (never mind where it is located)
2. Open screws (how many, where, its your probl)
3. Lift unit off (Does not? Oh, btw, failed to mention that ALL was for model -99)
lol. On other issuess repeat this as many times as there are boxes in maxima... =bs.
DO Check out bottom of page:
when i frist got my JWf ecu it's was hell tryin to get in and take out my old Ecu, so have fun on buddy on whatever you doing. The main problem for me was the backet holding the ecu, try takin out the backet as with the ecu it work for me.
pears
Sep 18, 2015 05:25 AM
