Question on Spraying
Old Mar 23, 2005 | 02:38 PM
XeroX's Avatar
Hella internets
I was just curious, can nitrous be used at high speeds? Like on the highway? i always hear of people spraying on launches and stuff. But would it be safe to spray when your already going around 60mph +? or would that be a death wish for the motor?
This may sound stupid, but i havent been able to find any threads relating to this kinda question.
Old Mar 23, 2005 | 03:15 PM
SonicDust187's Avatar
Its ok to spray it at 60 plus. But dont spray over 14 seconds straight.
Old Mar 23, 2005 | 04:26 PM
Jime's Avatar
I have only sprayed from 0 to 115 mph, that the fastest I have gone at the track. Never really tried to see what it would do on the highway. Would be interesting to take it up to say 120 on the highway N/A and then spray and see what it would do.
Old Mar 24, 2005 | 09:51 AM
XeroX's Avatar
Hella internets
Thats kinda why i wana get some juice for the max. Not only to pull some decent times with my crap auto b4 i do my 5spd swap, but to get some extra pull on the freeway when i wana have some phun.
But basically it is ok to spray no matter how fast your going, just as long as you are low enough on the RPMs to not redline...correct?
Old Mar 24, 2005 | 10:36 AM
Jime's Avatar
Also don't spray at low rpm's in 3rd or 4th, get it up to 3 or 4k. Spraying at low rpm in hi gears is a huge no-no. Thats what blows stuff up. In 1st it doesn't matter, I hit it right from idle because the engine can rev freely but in the high gears it builds up huge pressure in the combustion chamber and just increases rpm slowly.
Although if you hit it at a low rpm in the auto it will just shift down anyway, but just to be safe don't spray until after it does kick down to a lower gear, you could possibly over rev fairly quickly under those conditions.
I have only sprayed on the highway a couple of time and when I did I was in like 3rd at about 4k wot and then hit it.
Old Mar 24, 2005 | 01:31 PM
fknh8d's Avatar
i sprayed in all gears pass 140+....i think its okay.....i been spraying for like 20k miles at 75-175 shot....i think its okay...the only mods i have is intake, clutch, straight gutted cat no piping after cat.....with punching at 2nd gear and 3rd gear down the track i can only hit 14.00@100mph because i am spinning tires on first and second......on the highway i dont spin tires....it just pulls
Old Mar 24, 2005 | 09:48 PM
subs1000w's Avatar
i see no piont in spraying in the lower gears unless you like replacing tires all the time
3rd and 4th is pretty much all i use
Old Mar 25, 2005 | 10:09 AM
XeroX's Avatar
Hella internets
sweet, im starting to understand this nitrous stuff a lil better now, thanks guys
Old Mar 30, 2005 | 01:48 PM
C MAX's Avatar
i sprayed from 80 to 140, but one time it got me i ran lean and poof!
Old Mar 31, 2005 | 12:09 PM
NisMo-Max's Avatar
Poof as In New Motor????????
Old Mar 31, 2005 | 01:34 PM
C MAX's Avatar
yes unfortunately. blew the rod straight through the oil pan . i dont have the ***** to go screaming down the highway like that anymore.
Old Apr 1, 2005 | 10:25 AM
NisMo-Max's Avatar
If You dont mind me asking. how much did that end up costing you??
Old Apr 1, 2005 | 11:04 AM
C MAX's Avatar
it ran me about 2900 bucks. im running s/c and nitrous so i try to avoid used motors. but if i blow again no more rebuilt for me i'll just buy a couple of used motors and beat em up.
Old Apr 1, 2005 | 12:43 PM
XeroX's Avatar
Hella internets
that blows...not the SC...the motor haha
Old Apr 7, 2005 | 11:45 AM
Deckdout2's Avatar
Play with my balls
so my safest bet is to spray in 3rd and 4th above 3k rpms. does the rpm range need to be somewhere on 5th and 6th, or is it ok to be in any range in those gears? more than likely i'll probably only spray in 3rd and 4th, but would like to know about it with my other 2 gears left. :grin:
Old Apr 7, 2005 | 03:04 PM
C MAX's Avatar
for our cars 2nd and up is critical when using nitrous, you get the biggest gains from 2nd to third and should be fuel safe as long as your at wide open throttle.if you spray from third the race is basically over and if you spray from first you get no traction. i wouldnt redline out the final gear spraying though that can get kind of dangerous.
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
