19" wheels!!what size tire are you running?
Old Mar 23, 2005 | 05:05 PM
REYMAX77's Avatar
who has 19" wheels here what size tire are you running. i was thinking of going with 225/35/19 0r 235/35/19 im getting my tokico illuminas and tokico spring set up. does anyone have pics? please post or email them to me thanks
Old Mar 23, 2005 | 05:19 PM
96white's Avatar
www.tirerack.com
Old Mar 23, 2005 | 05:23 PM
Max Mutes's Avatar
No. Get a 19" wheel with a width of 8.5" and go with: 245/35/19. Some do 245/40/19, but it's not recommended. << I WANTED to do that for more sidewall protection, but it would alter the speedo way too much so I'm not going to anymore.
Old Mar 23, 2005 | 05:27 PM
REYMAX77's Avatar
but my new wheels are 19 x 7.5
Old Mar 23, 2005 | 05:30 PM
Max Mutes's Avatar
Boooo. Well...then go to Tirerack I guess. I havent heard of any .org member on here with 7.5 19's so sorry I can't help you out.
Old Mar 23, 2005 | 07:42 PM
A Flood99's Avatar
do a 235/35/19 for a 19x7.5
Old Mar 23, 2005 | 07:46 PM
REYMAX77's Avatar
ok thanks!!!!!!!!!
Old Mar 24, 2005 | 02:20 PM
erty67's Avatar
Decal Specialist
7.5" what kind of wheels are those? I'd make sure.....35s on a 7.5" wheels makes me nervous
Old Apr 14, 2005 | 06:47 PM
TDotMax's Avatar
What about 19x8? I'm getting 235/35/19's...Dropped on Progress and Illumina struts...5th gen BTW
Old Apr 14, 2005 | 06:54 PM
Royal_T's Avatar
I'm getting 19X8.5 w/ +34 offset, Should i go with 245/35/19?
Old Apr 14, 2005 | 07:11 PM
$tillenmax2k
If you get 225 or 235's, make sure it's a 40 series profile sidewall for 19's. You will be very thankful later.
Old Apr 14, 2005 | 07:39 PM
TDotMax's Avatar
Explain why? I think 40 would look to big.
Old Apr 14, 2005 | 10:47 PM
erty67's Avatar
Decal Specialist
I have 245/35s on my 19x8s....235s will be fine and 245s should be fine
Old Apr 14, 2005 | 11:26 PM
VIP Maxima
im planning to get 245/40/19 for my 19x8's
Old Apr 15, 2005 | 09:36 AM
Battle Max's Avatar
if you listen to "standard" plus sizing a 235-35-19 is the size you should run with a 19x7.5 rim.
Old Apr 16, 2005 | 08:52 AM
Jayzmax04's Avatar
I had this question a while back. I wanted 245/35/19, but I went with 245/40/19 and im very glad I did. I feel enough road vibration as it is, and I cant imagine going any lower. Just my taste.
I also get better rim protection with the 40's. I dont think its too big at all.
Old Apr 17, 2005 | 09:56 PM
Tommy Boy's Avatar
I'm going with a 255/35-19 on 19 x 8.5 with 35mm offset all around. They are not mounted yet so don't know about rubbing issues. But I'll let you know. The car is stock ride height for now, but that'll change soon too!
Old Apr 17, 2005 | 10:20 PM
speedymax99's Avatar
im rideing on 245/40 19 with Teins Coil-Over and it ride a lot beter the when i had the 245/35-19
Old Apr 18, 2005 | 06:48 AM
euromaxima's Avatar
I have a 19s 7.5 with 235/35/19 tire with a 42 offset
Old Apr 18, 2005 | 10:12 AM
SEmy2K2go's Avatar
Go BUCKS!!!
19x8" wheels + 245/35/19 Nitto 555 tires
Old Apr 18, 2005 | 10:23 AM
VIP Maxima
i seen 245/40/19 up close on speedymax's car. i couldnt even tell they were 40's till he pointed it out.
Old Apr 18, 2005 | 02:33 PM
Triple8Sol's Avatar
I miss the .org!
For 19x7.5 you'll want to go 225/35/19....
Old Apr 18, 2005 | 05:02 PM
Max Mutes's Avatar
You have 8.5 width? What offset are you running? No rubbing whatsoever with the coilovers on a 245/40 series?
Mike did you take a ride in it as well or no? I should be only goin with H&R's, but might jump ship to S-Techs so curious on first hand thoughts/opinions, especially with such a low drop on Coilovers.
Old Apr 19, 2005 | 10:34 PM
the width of my wheels is 8.5 and my off set is 42 and i do not rubb at all
Old Apr 21, 2005 | 01:22 PM
Max Mutes's Avatar
Hmm...interesting. Beautiful info sings to my ears. I wonder if I'd be able to pull this off with Illuminas/S-Techs...
Old Apr 21, 2005 | 10:01 PM
00SEMAX19's Avatar
I have 7.5's with 2 45mm and 2 35 mm all 2353519 fits perfect nito tires. Car is slammed 25.5 inches all the way around, no rubbing
Old Apr 22, 2005 | 05:17 AM
Max Mutes's Avatar
Damn, you must be into the Earth's Mantle by now...
Old Apr 22, 2005 | 04:53 PM
FourthGenMAX's Avatar
225/25/19, way too skinny, get atleast a 35 series, if not 45
Old Apr 23, 2005 | 07:11 PM
KCMAXX's Avatar
KC's FINEST
I had 255/40/19's on my 6th gen until I replaced them with 20's. Now their on a 00 max with no problems at all. Only thing we had to do was remove that dust cap on the rears...
Old Apr 27, 2005 | 12:32 PM
do0ki's Avatar
i have 19x8.5 and i have 235/35/19
Old May 1, 2005 | 03:13 PM
KCMAXX's Avatar
KC's FINEST
I sold a set of 255/40/19's to a buddy with an 00 Max. They fit fine. No rub and fills the wheel well up nicely. (stock height) I think they look better on his than they did on mine...
Old May 2, 2005 | 06:02 PM
Nathan's Avatar
I have 245/40's on 19x8.5" wheels and nobody really notices that they are larger until I tell them. I actually like the look of a slightly larger sidewall personally, and as jaysmax04 said, it will give the rim more protection.
homeyclaus
Sep 3, 2015 06:15 PM
maximaham
Aug 20, 2015 10:23 AM
twotonezed
Aug 16, 2015 11:41 AM
