A question to any who have installed SS clutch line
Old Mar 29, 2005 | 09:41 AM
hacim105's Avatar
I finished installing it and my clutch engagement changed from being up where the clutch pedal is almost released to right down where you just start releasing or lifting up the clutch pedal.
Is this normal? If not, is it possible that there is still air in the lines?
The reason I don't think there is air in my lines is because my clutch is a lot more responsive now with the SS line and it doesn't feel mushy like it has before when I've had air in my lines, and it grabs really strong.
If anyone has any ideas they are greatly appreciated. Perhaps I just have to get used to this new feel of my clutch.
Old Mar 29, 2005 | 09:56 AM
vsamoylov
when i installed mine, nothing change except fot the pedal feel. maybe it cause i bled from the master all the way down to where th e clutch goes into the casing. so i guess that would mean both the slave and master cylinders i bled.
Old Mar 29, 2005 | 11:56 AM
hacim105's Avatar
Well I'm going to try and bleed it more after work, hopefully it will be fixed.
Old Mar 29, 2005 | 01:26 PM
Matt93SE's Avatar
STFU n00b!
be sure to bleed from both bleed points, not just one.
Old Mar 29, 2005 | 03:01 PM
maximazation's Avatar
does the SS clutch line make the clutch feel stiffer?
Old Mar 29, 2005 | 04:42 PM
Matt93SE's Avatar
STFU n00b!
no. it just improves pedal feel..
Old Mar 30, 2005 | 10:28 PM
MDeezy's Avatar
dont you have to bleed in order too? the high point (under intake) then the low point (right at the surface)
Old Mar 31, 2005 | 11:10 AM
vsamoylov
it would make more sense to do it that way.
Old Apr 1, 2005 | 10:13 AM
SPiG's Avatar
SomePsychoGuy
Is there an order? I did the master cylinder first and then the one on the strut tower. If I do it again I am just going to buy some speed bleeders. I am lazy when it comes to things like that.
maxima-junky
Oct 21, 2015 05:17 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
maxima-junky
Aug 13, 2015 09:59 AM
MikesChevelle
Aug 10, 2015 10:53 AM
