to those with a flywheel
Old Apr 1, 2005 | 02:10 PM
jarrod91se's Avatar
was thinking about getting the udp and a flywheel. i was reading the thread about udp and got some good info, now what about the flywheel, reviews? and how was the installation? thanks
Old Apr 1, 2005 | 02:12 PM
Jeff92se's Avatar
I'm needing a caw
Don't you have a flywheel already?? heh
I have a Fidanza flywhl and the ASP pulley. Both work well together. Both are worthwhile mods.
Install for flywheel. Same as for the stock unit.
Old Apr 1, 2005 | 02:14 PM
jarrod91se's Avatar
no i do not have either....yet was wanted to know more about em
Old Apr 1, 2005 | 04:14 PM
twinkle's Avatar
they are made of aluminum, so they weigh less, and less rotational mass means more usable power, wich is good, what else is there to really know?
Old Apr 1, 2005 | 05:08 PM
James92SE's Avatar
2 VE's are better than one!
I've only driven a bone stock VE 5spd one time, and the biggest thing I noticed was how much easier and quicker mine revved than the stock one, and that's due to my UDP and aluminum flywheel. Together they really do make a substantial difference
And jarrod.. you do have a flywheel already, just not a light one
Old Apr 1, 2005 | 09:40 PM
Wiking's Avatar
Whose flywheel exploded on the engine? Would like to have the pic here now... If KS is a killer, lightened [read: will not dampen harmonic crank wibrations] flywheels are bombs.
Check Out: http://archive.mirafiori.com/The_X/2375.html
...and google for more.
Old Apr 2, 2005 | 03:31 AM
swowlinc's Avatar
1993 SE
My 11lb flywheel came apart in my car but it turns out, it wasnt a Fidanza.
Old Apr 2, 2005 | 07:19 AM
OBEEWON's Avatar
who makes the UDP for the SE? me no findy...grrr
Old Apr 2, 2005 | 07:58 AM
Mizeree_X's Avatar
Getting back to his roots
C'mon dude, this thread is still on page 1:
http://forums.maxima.org/showthread.php?t=391860
Old Apr 2, 2005 | 10:32 AM
Jeff92se's Avatar
I'm needing a caw
Flywheels do not reduce harmonics.
Old Apr 3, 2005 | 10:00 PM
mtcookson's Avatar
i have a fidanza in mine and it definitely makes the engine rev must faster. surprisingly my maxima has better throttle response than the mr2 i just got. even with the lower compression and leaky everything it revs much faster when you blip the throttle (which is very surprising when the mr2 has a 1.8 liter 4 cylinder)
i bet a lot of it has to do with the lightened flywheel. its definitely much lighter than stock and definitely helps out a lot. the only downside to them is launching tends to be a bit more difficult but its easy to learn once you've used it a bit.
Old Apr 4, 2005 | 06:35 PM
Maximum Depth's Avatar
I have heard nothing but good things about upgrading to a fidanza flywheel, and have one here awaiting installation. I do have hesitations about the UDP, as my black leather interior (which I love) requires a lot of a/c cooling, and the UDP will only reduce the effectiveness of the a/c. Comments?
Old Apr 4, 2005 | 08:38 PM
swowlinc's Avatar
1993 SE
Pure misinformation... The ASP UDP will not affect your a/c or heat.
Old Apr 4, 2005 | 11:55 PM
tmnismo91's Avatar
Black leather interior here with an Unorthodox and my a/c is frigid.
-Sean
Old Apr 5, 2005 | 07:16 AM
internetautomar's Avatar
mod or sell?
any UDP will make your compressor turn slower which could cause reduced effectiveness.
will it be noticeable?
not likely.
Old Apr 5, 2005 | 10:33 AM
Thanks guys, for the feedback on the UDP. Now that my misinformation has been corrected, I can pursue that mod without reservation. Can't say enough about the good spirited nature of 3rd Gen Maxima owners. You guys are great!
Old Apr 5, 2005 | 02:09 PM
twinkle's Avatar
have any of you guys had a problem with hesitation caused by the fidanza's like some of the forced induction guys are complaining about?
Old Apr 5, 2005 | 10:35 PM
MrGone's Avatar
nope, but sometimes if I step on the gas to much the wheels spin
Old Apr 7, 2005 | 08:22 AM
Lordrandall's Avatar
Fidanza + ACT Street = win
Old Apr 7, 2005 | 10:11 AM
mtcookson's Avatar
fidanza + spec stage 3 + turbo + larger wheels - boost leaks = super win
KabirUTA13
19
Oct 17, 2015 02:15 AM
kenc15
Sep 25, 2015 06:38 AM
